Question about Toshiba 46HM95 46" HDTV
Shadow along side
I have a 61 ' samsung and had the color wheel repair now tv works fine, but now theres a black smuggie shadow along one side
  • cavello1 Jan 20, 2009
    from top to bottom on left side about 2 to 3 " and along bottom also 2 to 3" on bottom fom one end to the other almost looks like fingerprints and dirt thanks
  • 54 Answers
Does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Posted on Jan 20, 2009
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
Just replaced color wheel. When TV turned on seemed fine but then i noticed a grey/black shadow band on one side. What could be the cause?
I had a similar issue with mine from the factory. There was a grey/black shadow in the upper left. Called for repair. The guy took off the circular access panel on the left back side and there was a fingerprint on the projection lense. He cleaned it and it disappeared. Sounds the same. Maybe touched the lense replacing the color wheel?
Sep 06, 2010 | Samsung HL-R5678W 56" Television
There is a line, like a shadow on the right side of the screen all the way up and down. What is that from?
Your TV uses a "Light Tunnel". A part which has various filters to create the proper "color" of light needed to produce the picture. Sometimes, one of these filters slips, causing a shadow to appear in a corner or along an edge. The appearance is this defect is more of a shadow and does not have a sharp, defined edge (like a letterbox image would). You can replace the entire light engine to repair this or just replace the light tunnel. The light tunnel repair is much more difficult... I would recommend a service call, as this is not a simple procedure. I hope this helps.
Mar 17, 2010 | Samsung 61" Slim-Depth DLP HDTV
Replaced color wheel on my Samsung 61" HL-P6163W. Colors on the TV are off. How do I reset this? I've seen posts regarding a jumper wire. Does this apply to my model? If so, where is this jumper wire?...
did u not pull the jumper if u put in a new air bearing color wheel it spins much faster u have too pull the jumper on the board beside the little fan its black just pull straight out its black little plastic thing look on the silver slotted case youll see two little square opening one has the black jumper right there pull it out did mine already see ya
Dec 29, 2009 | Samsung HL-P6163W 61" TV
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Possible bad color wheel? HLN617W
Replace the color wheel and you should be OK.
Feb 19, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba 46HM95 46" HDTV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
