posted by sally001 on Jun 20, 2007
My fax machine has been working. I went away for a while, came back and replaced all the ink cartridges with the correct brother ones. Now the machine won't do ANYTHING and the little window says "close cover." I have checked and re-checked and cannot find anything open.
Oh- It won't turn off either
Comment by sally001, posted on Jun 26, 2007
You are RIGHT!!! I am returning the machine, as it is only 11 mos. old
Thanks for your help.
2 Other Users Have The Same Problem
Comment by paperchaser, posted on May 24, 2008
Refuses to turn off with the button !!!!
I have a problem with Brother MFC- 240C 3 in 1 printer turning off. One out of ten times it will turn off with the button. Any other time I must pull the plug. Anyone have any help with this problem ??
Best Solution
posted on Jun 21, 2007
try unplugging the machine wait a few minutes and retry!
Comment by john A, posted on Jun 26, 2007
If the machine wont turn off and unplugging it did not work it means the main logic board is defective. In this case the machine is bot feasible to repair.
Rating Locked! (?) sally001 has rated this solution as Helpful
Solution #2
posted on May 30, 2008
Cheap Brother TN250 toner cartridges and Brother TN-250 supplies from ConcordSupplies.com <a href="http://www.concordsupplies.com/brother-tn250-toner-cartridge-brother-tn-250/33092.htmlhttp://www.concordsupplies.com/brother-tn250-toner-cartridge-brother-tn-250/33092.html">http://www.concordsupplies.com/brother-tn250-toner-cartridge-brother-tn-250/33092.html</a>
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother Multi-Function Center
Email this problem
Email this problem
Can you Help with these Printers problems?
Brother Multi-Function Center MFC-240C...
Blurred when i pdf the...
Please help me solve my problem... Answer This...
Brother MFC 240C - prints lines...
When printing, i get lines in... Answer This...
unable to print 50
unable to print 50
On my brother DCP-330C Please... Answer This...
install ink lc51
install ink lc51
how do i install the ink...i... Answer This...
Brother MFC-210C won't print
Recently replaced the ink... Answer This...
Repair Service
Find Printer Repairman Near You:
