Computer won't boot up
My grandson gets a black screen that and it says the following file is missing or corrupted:C:\WINDOWS\ZMM32.VXD
THEN THERE IS A PLACE THAT SAYS TYPE THE NAME OF THE WINDOWS LOADER (e.e.,C:\WINDOWS\ZMM32.VXD)
What can i do to correct this problem
  • lady2di414 Jan 17, 2009
    I believe it is Millenium not XP
    Sergeant:
    Champion:
  • 318 Answers
    Problem Solver:
  • 6 Answers
The best way to go here is to run a windows repair. Presuming that your grandson has a copy of Windows (XP, I'd imagine, given the name of the driver you've listed), he should be able to put the cd/dvd in the drive, and boot from it (this may require him to specify booting to a cd/dvd drive in the computer's BIOS - which can usually be accessed by pressing either DEL or F2 shortly after turning the pc on).
Once the cd/dvd has booted up, an option will be given to repair XP. Do this, and your problem will be solved. Be prepared to lose some of the settings you have in windows, however - but no data will be lost.
Posted on Jan 17, 2009
  • 716 Answers
You Can Try Using The Safe Boot Option Or Obtain A Windows Xp Repair Disk.
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
System32 file missing or corrupt
You may find some help on YouTube. Open the link below and check out the thumbnails on the right for further help
PC Repair File missing or corrupt windows system32 config system
Oct 10, 2017 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
My hp pavilion 513n has completely stopped working! I need help!
Start the computer, and keep pressing F8 until you get a "boot" menu -- white text on a black screen.
Select "safe mode with command-line", and see if Windows will start.
If it does, enter 'CHKDSK C: /F' to get Windows to check the integrity of the file-system.
Then, find a friend with a genuine Microsoft Windows XP CD-ROM. Boot from that disk, and choose "repair", and see if the boot-process can "repair" your installed copy.
Jun 23, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I Unable to access my Laptop please help me out.
hi,
do not choose safe mode,instead choose the start normal, If still you can not load and error exist, there might be missing of your files or your files are corrupted..Format your computer and back your important files then install new (OS) Operating System.I hope this may help you.
best regards,
kaybicks
Feb 27, 2010 | Toshiba Portege 320CT Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Computer
Get the discs that came with your computer and boot off them. When your computer is on the dell screen when you first turn it on it will say something like "hit f3 for boot menu". You need to hit the button it specifies and select your cd drive. It will say press any key to boot from cd, and as you may have already guessed you want to hit any key. Then when a windows screen comes on you need to hit r and follow the onscreen instructions from there.
Apr 05, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Missing or corrupt files
well you will need a windows 98 disk to fix the problem. so if you don't have one or can't get one your best bet would be to take it to a technician.
Mar 08, 2009 | Computers & Internet
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
