Question about Kenmore 22422 Top Load Washer
Machine will not agitate
I have a Kenmore elite top load washer. I can not find any model number for this machine. Anyway the machine works it does everything but agitate. I should not say it does not agitate because it does move slightly. It does not make any noises it shouldn't. I would like to know if it is worth fixing and if so can I fix it. Can anybody tell me how to fix it. Thanks.
  • 23 Answers
Most likely it's either a broken belt, or the motor is going out. to check it you need to take the outside casing off, not sure exactly how to do that on that model. Anyway open it up, check under the drum for a belt, if the belt is in tact than it's the motor, in which case. Personally I wouldn't put in the effor to replace. as to where you can get a belt if it is broken, I don't know that either. Good Luck
Posted on Jun 20, 2007
SOURCE:
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite 22982 Squeaks during agitation
I'm pretty sure what you are hearing is the outer tub sliding on the bottom frame. There are three tub wear pads located around the top of the frame between the tub and the frame. Click on this http://www.partselect.com/PartDetail.aspx?Inventory=334620&SourceCode=8 these are the parts that I think you will need. You can click on the parts select home at the top right of the page and it will take you to their home page. There you can enter your complete model number and it will bring up diagrams of your machine . Once you find these part the diagrams willshow you where these parts go. Good luck.
Nov 24, 2009 | Kenmore 22982 Top Load Washer
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
Agitator on my washer is loose
Replace the agitator dogs in the top part of the agitator. Parts are about $7.00.
Jul 17, 2009 | Kenmore Washing Machines
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 22422 Top Load Washer Logo
59 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
