Question about Whirlpool LER5636P Electric Dryer
Won't turn on
I have a whirlpool supreme 7 cycle dryer and it just stopped working. The light works but I go to turn it on and it won't turn on. Please help!
  • 979 Answers
Check the breaker to it, then check the wiring in the back of the dryer. It is possible a wire has burned off the connection. It is 220 volts and the one that is working could be the one that is supplying power to the lights, the other leg is needed to power the drum and heater. You have a thermal fuse in there also that is probably located under the top. You will have to remove the top, 6-8 screws, to get to it. Once you get to it, you try bypassing the thermal fuse and connect the 2 wires and it should come on. If it does, then you can replace it at an applinace store for 15-20 dollars. Try this last after you have checked the other things. This takes the longest. Let me know how this does. Good luck.
Posted on Jan 17, 2009
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Whirlpool dryer model wed5600sq0 won't cool down
If it does not shut off during the cool down part of the cycle then the issue is with the electronics
Mar 10, 2012 | Whirlpool Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
Dryer won/t work
Hello chuhunghuang
Welcome
You said, your control lock light is lit. dryer will not work
Let me know how it goes!
Try ,
Pressing STOP/CANCEL to clear the display.
If this does not work.
pull the plug for 5 minutes or if you can't reach the plug you can turn the power off form th breaker for 5 minutes.
This should reset the system.
Bless You huuum
Please leave a rating before you leave the site!
Oct 12, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
