Question about Whirlpool Duet GHW9150P Front Load Washer
Flashinf H F
My washer is stopping about 10 mins into the cycle and starts to flash hf
  • kalen22 Jan 17, 2009
    We have had subzero temperatures and I am thinking the water line is frozen. However, we got it thawed and I saw water in the machine. It still stops and flashes H then F.
  • 640 Answers
Check your fill hoses,,for kinks,,or clogged,,the unit is detecting no water ate one or booth of the fill hoses..clean your screens,,,onthejob
Posted on Jan 17, 2009
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have whirlpool cabrio top load flashes f then 51
I had the same problem and Whirlpool will not do a recall on these washers. But FINALLY one day I was so tired of it stopping so often in a few minutes that I called Whirlpool and they said that it was a known problem and will be sending someone to replace the curcuit boards at no charge to me.
So get your manual out and call the Whirlpool people so that they can do the same for you!
Apr 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Can't clear the "HF" code
Does your machine have a flow meter? Several items can cause this to happen.
Follow this link to see what the flowmeter looks like.
Pop the top by removing the three screws on back top and push back and lift the panel. Behind the white box or dispenser on the left hand side you will see a black tube going to your fill valves, if there is one as pict at the link, shut off the water, undo the clips and noting flow direction fasten the leads of a ohm meter on to the leads. Watching the display blow into the flow meter, the ohms should go from 0 to above 14 if not replace. Also check the serial connect and trace to the ccu and unplug, plug in the connect.
Sep 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
234 people viewed this question
Dan Webster
Dan Webster
Sal De
