Washer fills but will not agitate. - Washing Machines
  • cheapiephp May 11, 2010
    Have You Checked The Motor And Belt?
  • 15,935 Answers
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
RAS7233KQ0 fills but will not agitate
you probably have a loose or corroded wire to your agitate solenoid unplug the washer and, visually check this
Jun 09, 2009 | Roper RAX4233PQ Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Agitator not working
There are several things that can cause your machine to fail to agitate. First of all, you need to ask yourself a few of these questions:
1. Does the washer fill normally, initiate agitation cycle and just the agitator is not moving? If so, the transmission and motor coupling are likely good and the agitator has probably worn out the dogs that cause it to grip properly. The agitator dogs will need to be replaced and you shouldn't need a new agitator. (rough estimate = $5.00 to $6.00).
2. Does the washer fill normally, but stops when the agitation cycle is to begin? If so, I would suspect a faulty lid switch. The lid switch will allow the washer to fill, but will not advance the timer beyond that point on some models. (rough estimate = $35.00).
3. Does the washer fill normally and makes a loud grinding noise when the agitation cycle begins? If so, I would suspect your motor coupling is bad and needs replaced. (rough estimate = $18.00 to $20.00).
4. Does the washer fail to fill at all? If so, I would suspect a bad fill valve, pressure switch remaining shut off and/or timer. (rough estimate for fill valve = $35.00, timer = abt $100.00).
These questions are not all inclusive, but these are some of the more common problems I have encountered. If you can provide me with a little more symptom elaboration, I can lead you in the right direction and get a part number and a better price for you. I will need your EXACT model number (located somewhere along the lid opening. Post back with your comments if you need my assistance. A good majority of the problems associated with Whirlpool top loaders can be easily repaired by the average consumer without assitance from a repairman. I hope this information is helpful to you.
Jan 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
