Question about Fisher and Paykel GWL11 Top Load Washer
The drain/circulation pump quit on my fisher paykel gwl11
I ordered a new pump from sears parts and the pump arrived today.  I thought I would drain remaining water so I plugged in the machine and all the lights and sound came on like normal when first plugged in.  I then advance it to the rinse cycle to drain the tub and hit start everything goes dead.  I then unplugged the machine removed the old pump and let the water drain on the floor,  clean up and install the new pump.  I then plug in again and no lights or sounds.  I look for a inline fuse at the control module and nothing on the outside of it.  I want to take it apart but I thought I would look for a service manual or a answer on line first.  Can you help?
  • FatBear Feb 03, 2009
    My problem sounds the same except that I smell a slight burning smell.
  • Anonymous Mar 14, 2014
    I have had virtually the whole machine apart, cleaned everything rinsed the drum, the water pump cleaned all the pump covers, checked pipes for blockages and still can't get rid of this Fault Code. Machine starts its cycle, fills with water then doesn't drain. If I change the cycle manually the pump drains the water with no issues. Seems to look like a circuit board type issue that needs resetting?
  • 3 Answers
U need a new control board.the fuse is on the board.dave
Posted on Jan 25, 2009
Checked the control board for a fuse.  Found two fuses on the printed circut board.  Checked both for continuity, one had none a 6.3 amp fuse sodered into the board.  went to a local electronics store and purchased a similar and replaced fuse.  Everything works fine now.
Posted on Jan 17, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Our GWL11 washer stops during rinse, won't fully empty, shows code 37 in diagnostic. Can get pump to drain the tub (in pulses) in diagnostic mode and water circulates during wash. pump resistance is low:...
if pump resistance is low, you risk overheating and blowing your electronic board. you are best to order the pump. if you pause the washer during pump out, this will allow it to cool, then you can resume wash, but this will take you hanging around your washer while its going.
Sep 23, 2013 | Fisher and Paykel Washing Machines
Drain pump removal on F&P GWL11
Try to drain all the water out before removing pump.
so motor and other parts don't get wet when you remove pump.
Mar 23, 2013 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
We need a new pump for our Fisher&Paykel washer, Model #GWL11, tried order through a repairman, but did not come in. Where can we order one.
http://www.expertappliance.com/fisher&paykel-washer.html
Enter your model number and the part needed.
They claim to have it in stock.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do I change the drain pump on my Fisher Paykel GWL11? Where can I get a service manual?
If you call their technial assistance number listed in your users manual they will send you a manual for $49.00. That is the only source I know of. As for parts Sears Direct has diagrams of your model here. Just click on the link that matches your exact model (there are only 2 links) 50 /50 chance! :) http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GWL11&=part+number
The 68 page users manual in PDF format can be found here. http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606358.pdf
As for the step by step on the pump change regretfully I can't help you without seeing it myself. Hope this helps as it has taken 45 mins just to get the infromation above for you.
Jan 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Jun 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
May 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
577 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
