Question about SuperMicro Pentium III Xeon (TMR-004) Processor Board
WINDOWS XP PRO SERVICE PACK 3
LOADS OPERATING SYSTEM, AFTER A FEW MINUTES CRASHES AND STARTS OVER.
SUPERMICRO S2DGE XEON PENTIUM III 700MZ SET TO 7 ON MOTHERBOARD FOR CORE BUS RATIO, GOOD PC-100 MEMORY, GOOD HARD DRIVES,
SAME SET UP ON ANOTHER COMPUTER, USING SCSI DRIVE CARD AND NO IDE PCI DRIVES, 450MZ PII XEONS.
MOST UP TO DATE BIOS FROM SUPERMICRO.
    Novelist:
    Scholar:
  • 72 Answers
First off, please use proper case. All upper case makes it look like you are shouting. Thanks.
Try removing everything you can possibly remove from the outside other than the monitor. Remove any cards inside not needed to boot (sound, NIC, modem, etc.).
Disconnect mouse and keyboard, too if it will boot without a keyboard. Some systems will halt at the BIOS screen without a keyboard.
When you have a minimum config for booting, boot and see if it stays on. If so, one of the items disconnected is the culprit.
If not, reconnect keyboard (if disconnected) and boot into Safe mode by tapping F8 after BIOS screen. See if it will stay on in safe mode. If it will stay on in safe mode, problem is O/S.
If it won't stay on in safe mode, see how long it will stay on at the BIOS screen. If it will stay on indefinitely, you could have flaky RAM or possibly hard drive. Power off, unplug power cable, remove hard drive and see if you can boot to the Windows CD. If it will boot up to Starting Windows and stay on, probably not RAM although that is not a definitive test. At that point, I'd try another hard drive and see if the O/S will install or try wiping and reloading the original hard drive.
Let me know if you need more help.
Honest1abe
Posted on Jan 17, 2009
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
I CANT INSTALL
Adobe Photoshop CS2 have some system requirements to be meet before installation, the requirements are listed below: (if you don't meet any of the minimum you should upgrade your hardware to install this software) (hopes this helps)
Processor
  • To run Photoshop CS2, PC users should have one of the following processors: Intel Centrino, Xeon, Xeon Dual, Pentium III or a Pentium 4 processor.
    Mac users who want to install Adobe Photoshop CS2 need at least a PowerPC G3, G4 or G5 processor.
Operating System
  • Photoshop CS2 requires at least a PC that runs Windows 2000 or Windows XP. Windows 2000 users need Service Pack 4. Windows XP users need Service Pack 1 or Service Pack 2.
    Mac users can run Photoshop CS2 on OS X versions 10.2.8 through 10.3.8 at least. However, Adobe recommends versions 10.3.4 through 10.3.8.
RAM
  • Both PCs and Macs can run Photoshop CS2 with 320 megabytes of RAM though Adobe recommends running the program with at least 384 megabytes of RAM.
Hard-Disk Space
  • Before installing Adobe Photoshop CS2 on a PC, make sure you have at least 650 megabytes of hard-disk space free.
    If you are installing CS2 on a Mac, check to make sure you have at least 750 megabytes of hard-disk space available.
Monitor and Video Card
  • Adobe Photoshop CS2 works best on monitors with a resolution of at least 1024 by 768. A 16-bit video card is also required. These requirements apply to both PC and Mac users.
May 27, 2011 | Adobe Photoshop CS2 for PC
I'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
Dec 31, 2010 | Computers & Internet
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but...
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
Dec 20, 2010 | Mathsoft Mathcad 11 Full Version for PC
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
Caut un driver audio pt intel pentium 3 500mhz procesor deci va rog sa ma ajutati sa gasesc
Time of this report: 2/9/2010, 11:40:13
Machine name: PC-C662274E7060
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Italian (Regional Setting: Italian)
System Manufacturer: I.C.S. SpA
System Model: Olivetti MK800
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~840MHz
Memory: 192MB RAM
Page File: 212MB used, 158MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
ma puteti ajuta cu un driver audio va rog mult
Mar 08, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Printing Filemaker pro 7 from Windows XP
Only truetype fonts are supported in Filemaker Pro 7 and later (reference http://filemaker.custhelp.com/cgi-bin/filemaker.cfg/php/enduser/std_adp.php?p_faqid=636&p_created=1115172456&p_sid=OTFkUO1j&
p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF
9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjQ2OSwy
NDY5JnBfcHJvZHM9MSw4ODkmcF9jYXRzPSZwX3B2PTIuODg5
JnBfY3Y9JnBfcHNfYW5zX3VwZGF0ZWQ9JnBfcGFnZT0xJnBfc2
VhcmNoX3RleHQ9cHJpbnRpbmcgd2luZG93cyB4cCAicHJvIDcu
MCI*&p_li=&p_topview=1).
Likely need to update printer, or at least drivers... Thanks for rating FixYa!
Apr 13, 2008 | Microsoft Windows XP Home Edition
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
SuperMicro Pentium III Xeon (TMR-004) Processor Board Logo
88 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
