Question about DeLonghi DC312T 14-Cup Coffee Maker
Coffee machine leaking hot water also all lights come on front
Hi the machine is a la spaziale cjz it is leaking water from the boiler i believe also after you switch it on it is fine for a while. then all the main llights on the front come on and i can not use the machine afterwards i belive it to be the thermostat that is faulty is this correct thanks.
Kevin Murray 14 cup Delonghi coffee pot leaks hot water out bottom of coffee maker(seems to leak in 2 streams of water out of the vent)
  • 4 Answers
Buy another one there like 10 bucks...
Posted on Jan 17, 2009
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
La Marzocco Linea 3AV...water is coming out of group heads but is not hot. The boiler for the steam is hot. Help?
Your front brew boiler likely has a dead heating element or there is a problem with the electrical system for the front boiler.
Aug 03, 2011 | La Marzocco FB-80 Series 3 Groups Coffee...
When pulling coffee by opening valve, water leaks from spindle. Safety valve is leaking?
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar. if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
Feb 09, 2011 | La Pavoni CUA001R Cuadra Espresso Machine
Water dripping from my boiler/dispensing pressure gauge
If it is leaking from the gauge then have it replaced ASAP. It is easy to replace, just make sure machine is turned off and cooled and water is turned off.
May 12, 2010 | La Marzocco FB-80 Series 3 Groups Coffee...
When i try to brew coffee hot water pouring from under the machine cover and no coffee comes out
Hi
Leaking under the machine usually means 1 of 2 things. You have a ruptured hose or your boiler is leaking. Both are repairable. There are 2 types of boilers in the Saeco machines depending on its age. The newer machines have a stainless coiled tube in an aluminum heater. This would probably be a hose. The older boilers were a 2 piece with a gasket that will leak if not taken care of by descaling on a regular basis and done correctly. No excessive heat when descaling. Turn the machine on, then run descaler through the wand by opening the knob for water. Run 8 nozs through the wand then turn the machine off and let it set. Do this until the descaler is gone. The rinse with a tank of fresh water.
Jul 10, 2009 | Saeco Vienna Espresso Machine
Leaking water and coffee grounds behind and below drip tray at end of brew cycle
If you take off the top and start your machine you will see and hear if the boiler leak, try this first to work around your problem.
Let me know if i can help you more.
Best regards
/Mirran
Sep 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Water leaks from my Saeco Incanto after brewing.  It appears to be coming from the boiler or back of unit.  I also here a hissing sound which makes me believe that the water is in contact with a hot...
I think you have to replace your bolier in the machine.
If it is the boiler and you replace it, make sure to descale your machine regulary.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Water tamp
Try to descale the machine, if there are calcium around the boiler then it will not warm up.
May 08, 2008 | La Pavoni Europiccola EPC-8 Espresso...
La Spaziale
you should search for compatable termal fuses, it is not obligatory to buy them from the producers shop. look at fuse's data and name google it. you will find them near you in some electronic shop where you dont expect.
Apr 30, 2008 | Hamilton Beach FlavorPlus 43424 Coffee...
DeLonghi DC312T 14-Cup Coffee Maker Logo
568 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
