Question about Symantec WinFax Pro for PC
Any received fax fails
When a fax comes in- winfax will open up and it will show who the fax is from and then it will fail. I can send outgoing fax ok--but receiving it will fail?
  • Anonymous Feb 06, 2009
    shows the incoming fax, get no receive rate, and then my line goes busy and hangs up on the sender
  • 143 Answers
Problems receiving could be any number of problems. The first item I would check it to make sure no other devices are on the same line as the fax modem, such as a fax machine. This can cause a problem for a fax modem to receive faxes when another line is being picked up and listened to at the same time.
http://www.getfaxing.com/forums
Posted on Jun 27, 2009
I have a BSNL boardband connection, can you tell me how can I configured?
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
Dec 10, 2010 | Symantec WinFax Pro 10.0 for PC
We cannot receive any faxes and get the error '
We've seen this error many times, and in most cases the problem is due to mismanagement of the send and receive logs. You probably have way too many faxes in your Receive Log (or, some corruption) You should read this
http://www.getfaxing.com/winfax/2009/08/18/organizing-your-faxes-with-the-winfax-pro-message-stores/
Mar 22, 2010 | Symantec WinFax Pro for PC
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
Winfax attempts to fax but fails.
hi,
my system is very slow. my system settings suddenly changed.what's the reason?
Jun 25, 2009 | Symantec WinFax Pro for PC
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
How can i refresh my send logs automatically ?
You can't, if a fax failed, and you leave it in the log, its listed there as a failure. If you're manually resubmitting the fax, while its in the outbox being re-transmitting or waiting, you can delete the old entry that failed in the send log. http://www.getfaxing.com/forums
Sep 08, 2008 | Symantec WinFax Pro for PC
WinFax Pro 10.0
I don't know the Operating system you are using but that version, as I remember, had a few problems. Suggest you check to A) make sure it's fully compatible, B) Check the supplier site (Symatec I believe) for issues...(under support), and C) If all else fails uninstall and reinstall. Use Ccleaner to clean the registry before reinstalling (free and you can't make a mistake) and also delete the application folder (typically under program files in an automatic install). Do the latter after using the windows add/remove programs capability. This should do it. If not bug me.
Tango.
Feb 04, 2008 | Symantec WinFax Pro for PC
Symantec WinFax Pro for PC Logo
94 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
