Question about RCA RS2640 CD Shelf System
Expert advice I posted a problem with my RCA audio shelftop model RS2640. The speakers only buzz, with no radio or cd sounds unless they are disconnected or muted. The first line of the response from your expert, Inteng, said "off course it will stop buzzing when you mute the speakers," stopping just short of calling me a complete idiot. The reason I mentioned that the buzz stopped when muted is because on your site someone else posted the same buzzing problem, but in that case muting the system didn't stop the buzzing. To give a response like that to someone looking for help is unacceptible. I think Inteng needs and attitude adjustment. Thanks David Dempsey
  • 3 Answers
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. Used a NTE382
replacement and it has worked fine.
Posted on Nov 15, 2007
    President:
  • 3,130 Answers
Sorry you feel that way David. they may have asked you that question so the buzzing can be isolated. If the buzzing DOES go away when you mute the unit, that means that your problem is in the preamp circuit of this unit and not in the audio output stage circuits. The only problem with these shelf type stereos, is the cost to repair. As most of the time, the part and labor cost exceeds the cost to replace, but you can certainly make up your own mind on this matter. If you feel this unit is worth it to you to repair, go for the repair! Good Luck with this repair.
Posted on Jun 20, 2007
SOURCE:
Hit won't play anything no sound wil come out but a faint buzz
The audio output ic pack is shorted that is located near the power transformer. The ic pack must be replaced, but it will need to be dismantled to get at the part.
Feb 09, 2011 | RCA RS2640 CD Shelf System
I can not hear anything accept for buzzing on the spaekers wether I am trying to play radio, tape, cd or nothing at all.
Hello Sir, hi, the buzzing sound is a sign of an amplifier IC failure, this IC amp needs to be replaced. (this requires finding the spare part and soldering and desoldering that part, so a tech person is needed) have it serviced by an electronics tech guy.
May 08, 2010 | RCA RS2640 CD Shelf System
I have a rca rs2640 stereo system. The display, cd player, tape player, radio, and headphone jack all work. But when a cd, tape, or radio is playing, the speakers do not make any sounds. I know it is...
It sounds like maybe you have speaker wires touching somewhere. If they are touching it will blow fuses, especially if you turn the volume up to try to hear anything. DO NOT put bigger fuses in to replace the old ones, you will actually do more damage to your system because a higher volt fuse will allow a higher voltage to "spike" in your stereo and might just start frying internal parts.
Aug 10, 2009 | RCA RS2640 CD Shelf System
Buzzzing
Have the same problem. Mine was sitting idol for a long time & when trying it today it just buzzes. Tried to plug headphones in & no sound to them either.
Apr 03, 2008 | RCA RS2640 CD Shelf System
No volume
What was the "fix" on this problem Alex?
I realize its been 3yrs ago...thanx!
Dec 22, 2007 | RCA RS2640 CD Shelf System
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Buzzing noise
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Jun 19, 2007 | RCA RS2640 CD Shelf System
Home Stereo System
Sounds like a internal error on the amp itself. Maybe it caught a surge, I had a stereo unit that got zapped by the way it was unplugged from the wall.
Mar 25, 2007 | RCA RS2640 CD Shelf System
RCA RS2640 CD Shelf System Logo
345 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
