Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Water temperature control not working
I have a Whirlpool stackable top-loading washer and dryer less than 6 months old. Whenever I set the washer's temperature control to cold I get hot water coming into the washer. Whenever I place it on warm I get hot water coming into washer. When I place it on Hot I get cold water. The rinse cycles are supposed to always be cold but the rinse cycle now is always hot. What could possible cause my washer to decide to operate in an opposite manner than it is supposed to and what can I do to fix it?
  • 3 more comments
  • johnbb Jan 17, 2009
    Your right, that should be the problem--but it isn't. The hoses are hooked up correctly. It has worked fine for six months and then all of a sudden started the problem mentioned. I have checked the hoses for kinks and the hookups to the hot water heater and cold water inlet--they are both okay.  I am stumped. Please help.
    Nope, no work done on the unit since it was installed. Worked fine until 2 days ago. Anyway, I appreciate your help and the model number is V74T2MPP(3B).  Thanks,,,,johnb
    I don't think it is as small as a Thin Twin. It is a 27 inch washer/dryer stacked unit with model number WET3300SQ1 (or at least I think that is the right model number). The number came from the dryer door.
    Thanks. My washer and dryer is in a very tight place and it will take me awhile to get it out. I will get back with you as soon as I have it pulled out. Thanks again...johnb
  • johnbb Jan 18, 2009
    Thanks
  • 640 Answers
The fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Posted on Jan 17, 2009
  • 2 more comments
  • onthethejob1
    onthethejob1 Jan 17, 2009
    you have to give me all the facts,,laugh..now send me you model number...i believe if you did not have any work done on that unit and nobody did not work on your inlet vavle,,we have to look at the automatic temperture control..atc.....or the temperture switch...im here just send model number ok ..onthejob
  • onthethejob1
    IM SORRY JOHN THIS IS NOT A VALID MODEL NUMBER.V74T2MPP..IT SHOWS ON THIS SITE THAT YOU HAVE A WHIRLPOOL THIN TWIN..IS THAT CORRECT..ONTHEJOB
  • onthethejob1
    ok john this is pretty straight forward,,john i want you toshut of water to fill hose,,,now put unit on cold cold tun on...go to back of unit and see if the cold valve is humming the cold vavle only..or vibrating...
  • onthethejob1
    ok but im here til its fixed,,
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Stackable Washer Dryer won't fill with water
hi
first thought would be water soleniods but it is unlikely that both would fail you could try just selecting one temp and then swaping hose and select the other temp if it wont work on either then i would think it is not a sol. problem, lid switch could cause it not to fill also but you did say it would spin so that will rule it out ,its coming back to a module problem ,something to ponder on
cheers grant
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
908 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
