Question about Palm Treo 600 Handheld
Speaker Doesn't Work
The speaker on the phone won't work except right after the headphones are removed for a few seconds.
    Problem Solver:
  • 14 Answers
If you use a plug in set of headphones often, you have probably caused the contacts to spread apart inside permanently. The only solution (if that is the case) is to replace the headphone jack, or to (for the brave) attempt to insert a pin inside the jack and open the contacts so they are not pressed against the outside of the jack assembly.
Posted on Jun 20, 2007
Sony ericsson j20i speaker problem
When the speaker does not work, there can be different causes. Something got in the headphone plug, preventing the connection to the speaker when the headphone plug is out. Another bad connection in the phone, or even a defect loudspeaker. When you are no tech, just bring the phone to a repair shop and let a tech review the problem.
I would blow in the headphone connector with a bellow a photographer uses to blow away dust from the lens and sensor. DONT blow in yourself, because of the moist you bring in. And I would plug and unplug a few times to see if that can solve the problem. Not to often and if it does not help? please do option 1 visit a tech.
Apr 04, 2012 | Sony Ericsson Hazel J20i GreenHeart...
No sound at all when headphones are plugged in
Hi, I apologize in advance for not offering a solution. Have just trolled through the handbook (on-line) for anything that might offer a clue. It takes both high and low impedance units so that's cool. They say to use the phones to assist with speaker issues and there's nothing to suggest that any of the settings affect them. Depending on the impedance the volume levels can change a fair bit so I guess you've cranked it up to check. The fact that they turn off the speakers doesn't add a lot, it can often be a simple mechanical switch in the socket when the plug is inserted. Does the 'speaker off' indicator come on when you plug them in. The only other things I'd suggest is both try another set of phones regardless and the other is reset all the sound settings to factory and see if that has any affect. Else you likely have an issue with the phone interface circuitry.
Jan 05, 2012 | Sony STR-DE575 Receiver
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
I cant heard my songs or ringtones or phone calls or anything of my phone the sound is gone and everything is turn up to the max and still cant hear anything.. but when i put my headphones in the outlet i...
Switch off your phone and remove battery for 5 seconds and then put it back in. If it doesn't work, your phone's speaker is dead and you need to carry your phone to local LG customer service.
Aug 17, 2011 | LG Cell Phones
How do i wire the second speaker so they work as a pair
there is a black cord that comes with the speaker system with dual end headphone 3.5mm jack both ends that go from one speaker to the other main speaker is your right speaker left is the one with only jack insert the right has da power with sound cord toghether in one going out to amp with headphone insert also that goes to left peaker
Dec 18, 2010 | Philips MMS 321 Computer Speakers
I reinstalled my operating system after that my speaker disn't work
Sound is not working. Headphones would work just fine but the built-in speakers stopped working. try to update and reinstall the drivers. The speakers would sometimes work for a second when removed the headphone jack. sometimes it was a short in the jack connection or just a bad connector in the jack. Sooo, just plugg in the headphone jack a bunch of times and after about 20 seconds the speakers will work just fine.
Dec 14, 2010 | HP Pavilion dv6000z Notebook
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Palm Treo 600 Handheld Logo
56 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
