Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
ESAM 4500 making too cold coffee
I just got myself a Delonghi ESAM 4500 and even though I program it to make the coffee extra hot it is only warm. Around 65 degrees Celcius. Is it possible to program the machine so that the whole scale moves a bit up? I would like the setting "warm" to be warmer and the extra hot setting to be really hot (80 to 85 degrees Celcius) Is there a service code or something that will make it possible to move the setpoint for tixed temperature settings on this machine - or is it possible to "cheat" the machine by exchanging the sensor with another one?
PLEASE HELP
Rgds Michael
EwingElect
  • 276 Answers
SOURCE: Dear Sir, Do you know where I could download an
Hi. If you have not yet had any success, try http://www.delonghi.com.au/support/instruction_manuals/EAM_series.pdf
Posted on May 25, 2010
Testimonial: "Great Service, just what I needed !Many Thanks"
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
SOURCE: delonghi perfecto esam 5400 instruction manual. I
A small stone got pretty stuck in the grinder of my Delonghi esam 5400. Anyone knows how to remove it?
Posted on Mar 22, 2011
ginko
  • 19396 Answers
SOURCE: alternating 3 lights (1 cup,
Hi.
The machine is not flashing an error message. When a problem is detected you get an error message on display.
First hold down ESC (or STOP/CLEAR depending on model), just in case machine is stuck in programming mode.
Disconnect power cord for two minutes. Connect back and try a reset if the problem is not fixed:
•Press the CHANGE button and the appliance displays "RESET TO DEFAULT YES";
•Press the OK button to reset the factory default values;
•Press the MENU button to exit programming mode or NEXT to change other parameters.
If that does not work, try holding down rinse or descale. If the machine starts rinse or descale, complete the procedure. If machine gets stuck in rinse or descale, keep filling the container while performing the procedure.
If all that does not fix the problem, call Delonghi at the number listed on the owners manual, the machine is defective.
Try all the rest first, or Delonghi may ask you to do some of the same procedures while operator is waiting at the phone.
Regards.
Ginko.
Posted on Apr 06, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
I boutght mine from ebay but I dont know how 5o use it thankes
Go to google and right the name of the machine with the kind
Like
(Delonghi ESAM 4500 ) followed with user manual pdf
Open it
Save it
Then print it
If you can't just send the info and I'll send you the link
Apr 19, 2015 | Coffee Makers & Espresso Machines
I have Delonghi ESAM 6900....when using the automatic coffee function when it put the milk in the cup it's not very hot...???? I have put the coffee to extra hot....but still in the cup it's like...
If this ESAM is like the earlier 3500, the water heater element is actually a pair of heater elements in parallel but in the same aluminium moulded unit. Being in parallel they act independently
of each other. If one goes open circuit then not enough heat is supplied to the water. Result is coffee a bit hotter than luke-warm.
The only answer is to buy a new part. You can't replace the single duff element because it's in the moulding.
Aug 26, 2013 | Coffee Makers & Espresso Machines
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
568 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
