Question about Maytag Neptune MAH5500B Front Load Washer
Can't get the washer to drain after the door wqas stuck open by a piece of clothing.
  • Maytag Master
  • 8,220 Answers
Download a manual HERE
Posted on Jan 17, 2009
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Standing waterin the door opening seal after each load.
Sometimes small pieces of clothing get into drain system and plug off draing. Check before pump for clog.
Oct 02, 2009 | LG WM-2277HW Front Load Washer
Water won't drain
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Good Luck!!
Thanks
Jul 07, 2009 | Frigidaire Washing Machines
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE BLOCKAGE
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 02, 2009 | Miele Novotronic Premier 500 Front Load...
How do i get the machine to drain the water out.
you will need to run it through its cycles to get it to drain.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Jul 28, 2006 | Hoover AI130 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
