Question about Protron PD-DVR100 DVD Recorder
How to reset (manually) factory defaults?
Accidentally have chosen "progressive" during setup (my analog tv is not), and now the screen is scambled...!
Thanks! won'T PLAY DVD SCREEN SCRAMBLED BUT YOU CAN HERE CHANNELS CHANGIG PROPERLY BUT CAN NOT SEE PICTURE PROTRON PD-DVR 100 DVD RECORDER
  • HOLTBRENDA Jan 17, 2009
    DID NOT WORK I THANK YOY PEOPLE FOR BEING OUT THERE
  • 716 Answers
Unplug It And Hold Down The On/Off For 30 Seconds Then Release And Plug It Back In. This Should Reset It If Not Let Me Know.
Thanks For Using Fixya.com
Posted on Jan 17, 2009
  • Michael Fisher
    Michael Fisher Jan 17, 2009
    Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
    Sincerely,
    Michael Scott
  • Michael Fisher
    Another One Push The P-Scan Button On The Remote If Its Equipped And It Will Take It Off.
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm ge
Cyberhome DVD-1600
To set the factory default settings just do the following:
  1. Get the DVD-1600 manual
  2. Open to the page which shows you how to set the player to factory default settings
  3. Switch on the TV and click to the channel that you will watch your DVDs
  4. Switch on the DVD player and make sure there is no disc in it - this ensures the DVD is not already in a menu or any other thing
  5. Follow the instructions in the manual to the 'T' although you will be unable to see anything
  6. If you follow the instructions correctly you should get back to 'interlaced mode'. By this time you will be able to see the DVD output on the screen.
Apr 12, 2009 | Televison & Video
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Zenith DVT412
If you are using analog video output to connect to your tv set and accidentally selected progressive scan from the setup menu you will loose the analog signal output.
Turn the unit on with no dvd inside and after the " no disc" message press stop (on the front pannel button) holding it for about 5 seconds. It will restore the original progressive scan configuration (value= no).
Jul 06, 2008 | Televison & Video
Reset to factory defau;ts
Small print in the manual says to hold down the 100/P.Scan button on the remote to toggle between progressive and interlaced. This was after I blindly tried to follow the setup screens in the manual and found that the manual doesn't match the exact screens (must be a firmware difference?) in the manual.
Also found that the factory default instructions in the manual do not include a yes/no confirmation screen.
May 26, 2008 | GoVideo DV2150 DVD VCR
Player was put on progressive scan and has stop displaying any video
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Problem during 'setup'
I had the same problem too now my TV screen is all black and I can't do anything. can someone help please. thanks
Dec 13, 2006 | Cyberhome CH-DVD 300 DVD Player
Protron PD-DVR100 DVD Recorder Logo
382 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
