Question about InFocus LP70+ Multimedia Projector
Projector does not display laptop screen - InFocus LP70+ Multimedia Projector
  • 231 Answers
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the projector checks first for active video during power-up. Highlight Default Source and click the left or right mouse button to toggle
among the options.
Posted on Jan 24, 2009
Same as above, i own a Toshiba Laptop and the external Function key is Function+F5, just try a couple of them and you should get a good result (*.:.*)
Posted on Feb 15, 2009
When I connect to projector laptop screen becomes blank and display comes only in projector
Depending on your laptop you will have to select FN button along with F4 and change the view mode to PROJECTOR + Laptop.
Aug 10, 2011 | Acer Computers & Internet
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
E6400 will not display on both screens the projector and notebook screen its one or the other. how do I get it to display on both at the same time.
Press Fn (Function button) and while holding it down press F5 repeatedly. It cycles through laptop screen only, projector only and projector + laptop screen.
Jul 29, 2010 | Dell Latitude E6400 Notebook
Couldn't see display on both projector screen and Vista laptop screen
the driver may not b installed correctly..or u have problem with the projector...
May 30, 2009 | Microsoft Windows Vista Home Premium...
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
He display through a projector is much reduced from the projector
The screen resolution on your data projector may not be able to display the screen resolution set by your laptop.
Adjust your laptop's screen resolution say 1024X768 first then adjust it up or down to see the effect.
You can do this from the Control Panel - Display - Settings. There is no need to reboot the laptop for the settings to take place.
Mar 03, 2009 | Dell Computers & Internet
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
Screen adjustment
Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
• With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
• Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
1.
In Control Panel, open Display.
2.
On the Appearance tab, click the Effects button.
3.
In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
If the projected image is not rectangular, try one or both of the following:
• Make sure that the projector is perpendicular to the viewing screen.
• Raise or lower the projector.
If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
• Adjust the brightness of the image.
• Check the projector lens to see whether it needs cleaning.
• Adjust the sync and tracking on the projector.
Sep 09, 2008 | Panasonic Videoprojector PT-LM1E...
Acer laptop stopped displaying to projector
Here is the deal. Right-click on desktop. Choose settings. Right-click on screen #2. Click on apply for new settings. The one additional problem you may encounter is the fact that the projector will display an area to the right of your laptop screen. In other words, move your mouse past the right edge on laptop screen. Look at projector image. See your mouse?
Aug 04, 2008 | Computers & Internet
InFocus LP70+ Multimedia Projector Logo
1,459 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
