Question about Dell Dimension 2400 PC Desktop
Hard drive not installed
I have a D-2400 that boots to the BIOS and when looking in the BIOS it says there is no hard drive installed and yet it is in the comp and spinning, I know this HD works so I am trying to figure out why the comp will not pick up the HD.
  • tazcat1869 Jan 17, 2009
    ok,the cmos battery was replaced and still the same thing. I turn on the comp and it goes right to a black screen saying that there is no hd installed.
    Problem Solver:
  • 6 Answers
Has this drive worked before or is this new to the machine? you might want to check the jumpers on the hard-drive.
Posted on Jan 19, 2009
  • 50 Answers
It might be the partition is damaged, if u have a windows cd, you can booth to that from the CD drive and see if u have to recreate your partition
Posted on Jan 17, 2009
  • 71 Answers
Check if the jumper is set to master or cable select...
    Sergeant:
    Champion:
  • 318 Answers
Did you install this Hard drive,,,did you set the jumper pins in the proper position i.e: Master - Slave - cable select??
If you did nothing to the computer and it's losing the hard drive,,then it could be the Cmos battery going dead,,make thge bios lose it's saved settings.
  • Alex M
    Alex M Jan 30, 2009
    If everything else fails..try replacing the cable that connects the hard drive to the motherboard.
    Sometimes they can go bad.
    Another thing to try would be to borrow someone else s hard drive and try to install that one,,if it still wont recognize the borrowed drive then you can be reasonably sure your own hard drive is ok and that there is something wrong with your IDE connection on your Motherboard.
Try to install a window 7 on a gatewaydx4870 I cant find the hard drive driver not found
If you are just trying to install from a bootable Windows 7 disk, the BIOS itself provides the basic hard drive driver, otherwise the system would never be able to load an Operating System. Now what you are probably experiencing is that the system cannot find the hard drive itself to begin the installation process. You need a hard drive in order for the system to load the files for the OS. When booting, press whatever key(s) is/are required to access the CMOS (BIOS). Look in the general information area to ensure that a hard drive has been detected by the BIOS. If one has not been detected, shut down the PC, then check the power cable and data cable connections of the hard drive to the power supply and mainboard, and then power up and check the BIOS again. If you still do not see a hard drive detected, should also look in the advanced settings area to ensure that the SATA port where the HDD data cable is connected to ensure that it is enabled and has not been disabled in the BIOS. If, after all that, you reboot and the drive is still not detected, then you have either a defective hard drive or mainboard. If the hard drive is showing in the general area of the BIOS, then look in the boot order/boot sequence area to ensure that the hard drive is included in the boot sequence. It should normally be the second boot device, with the optical disk drive being the first in the order.
Oct 16, 2016 | Hard Computers & Internet
My lenovo got a new harddrive and won't boot at all not even bios what to do? It's a g 560
You have to recover your MBR looks like, but first you need to remove the hard drive and see if it will boot without the HDD installed then get back to me ok. Also sounds like the BIOS may have failed if it wont boot without the HDD installed. But first things first.
Apr 04, 2015 | Lenovo Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Can i make a bootile usb for dell dimision 2400
If the BIOS setting for the Boot up device order does not have the USB as a boot up device then it is not possible to boot up your computer with an USB device.
For a Drive 0 seek problem -
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 19, 2012 | Dell Dimension 2400 PC Desktop
How can I replace DELL parts in a DELL pc with generic parts?
Your PC will accept any hard drive which is serviceable and properly formatted. If you are installing it as a second hard drive, ensure proper sequencing in the bios, else your OS will not boot.
Apr 24, 2012 | Dell Dimension 2400 PC Desktop
When i turn my acer aspire one d255 netbook on it says no bootable device -- please restart system i need help please
Hi
It looks as though the laptop is not recognising the hard drive, there is no hard drive fitted or there is a hard drive but the OS boot record has been wiped ( I know this sounds obvious but some people buy these 2nd hand only to find the hard drive was removed)
You need to check the hard drive is present by booting to the bios screen it should "see" the hard drive attached. If it is present, then you have a problem with the OS or a damaged hard drive. I think its DEL or F2 or F10 to access the bios, not certain.
At this point, you need to attempt to reinstall the OS, as this does not have an optical drive, you will need to obtain a USB Optical drive, go into the bios and see that it is recognised as a boot device. Do not worry about setting the boot order, the Bios will locate the rom as a boot device.
Attempt a start up repair, ie: wait until the installer looks for a previous installation of windows (if one exists) then allow it to install a repair installation. If it does NOT find this, you will need to doa full install. If at this point you have files you need recovering, a strip down of the netbook and removal of the hard drive will be necessary. You simply then get someone with a computer to jumper your hard drive as a slave and recover the files you need, as a full install requires the hard drive to be fully wiped.
Replace the hard drive after you have done this and proceed with the full reinstall
You can use a USB boot device, but to do this you will need to have access to another computer to make the boot installer:
here
Aug 02, 2011 | Acer Aspire One D255-2670
I want to install windows xp in my Intel i5-2400 dh67bl motherboard. how?
The first step is to make sure your system is set to boot from cd/dvd first, it is known as boot order. you can test if it is by simply putting the disk in and restart the computer, it will pop up with a line saying "press any key to boot from cd...." pressing a key on the keyboard will begin the install proccess, it's pretty straight forward, just follow the instructions on screen.
if however it does not boot fro the drive you will have to go into the BIOS and set the cd rom drive as the first boot device, do so by pressing the "Delete" or "Del" key on your keyboard when the system is turned on, you can press it repeatedly to make sure you don't miss it. once inside the bios what you are looking for are the boot options, or boot order, every bios is different as to where in the menu it is listed but it will be called boot order, use the arrow keys on the keyboard to navigate the menu system. after you have changed the cd rom drive to the first boot drive ( make sure you do not completely remove your hard drive from the boot sequence, as you will want it to be booted from after the windows install is complete) press the F10 key to save changes made and exit the bios.
May 29, 2011 | Computers & Internet
CANT FIND HARD DRIVE DURING INSTALATION
Put the hard-drive in another PC and see if it works .....
And if it do then.....
the pc that showed the error could have a problem in the bios setting (press F2 to get the bios during boot to get to the bios setting....try to reset the bios setting to factory settings)....or you could have to perform a flash of the bios.....
Apr 05, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
BIOS settings to boot from pen drive
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Apr 03, 2010 | Computers & Internet
How do i flash bios on my 2400 Dell Dimension
Your sister has a vivid imagination. Changing the memory and flashing the BIOS will chane nothing.
If you want to start from scrath then reformat the hard drive and reinstall the system but as you probably don't have a system backup disc this will prove impossible for you.
Your best bet is take it to your local PC shop (I don't mean the mainstream ones) and they will be able to restore your system.
You've learned a valuble lesson the hard way here. Always have a good antivirus programme installed, make sure it is up to date and do a full scan on a regular basis.
Sep 07, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
223 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
