Question about Uniden BC246T Handheld Scanner
'stuttering' reception On my bc246 the received signal 'skips' or 'stutters' every 2 seconds, making it difficult to follow. It happens when scanning, searching, holding, or on manual, everything. I've tried altering or switching off every 'pause' 'hold' 'timer' function I can find, wiping all system settings and starting afresh... Am I missing something or is the unit just faulty?
  • Iain McGregor Jun 26, 2007
    It was close call!. Thanks buddy!.
Thank you SO much. I thought the speaker was done for sure, but I turned out CLOSE CALL and everything works great!! :)
Posted on Oct 24, 2007
Usually the close call, weather priority, or channel priority settings are on...or just one of them.
Posted on Jun 26, 2007
SOURCE:
A minute or 2 after starting the machine and on any setting the machine starts to stutter, lights flashing and making a fast rhythmic noise
It sounds as though power is only struggling through to the motor intermittently.
Ignoring the possibilities of loose or bad connections or expensive circuit boards the motor could need new brushes.
I have had my machine nearly ten years and it is on its fourth set even though it doesn't get used very often.
I suggest you stop persisting with attempting to make it go. If brushes are the problem you could be making things worse so that it could need a new motor rather than some routine periodical maintenance.
I could be completely wrong - sorry if I am.
Feb 04, 2015 | Washing Machines
AM reception is fine for about 9 seconds and then the signal and audio drop completely. The only way to get signal back is to toggle to fm and back to am, then another 9 seconds of clear audio happens,...
Hello, I am sorry about your issue. Is the FM reception OK. AM signals are difficult to receive at times. Try extending the AM antenna and place it near a window. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo Audio Players & Recorders
Antenna
Really tough to get perfect reception with Rabbit ears. If you can somehow feed the line outside a lot of the times I have found that it helps improve signal reception
Jan 25, 2013 | RCA Ant121 Indoor Passive Antenna
My mouse keeps stuttering, I really don't know why. I changed the batteries and installed the latest drivers available. It works on and off. The stuttering really makes it unusable. I'm not sure what I...
When the mouse stutters, check the adapter plugged into the computer. If the little light on the adapter (labeled #2 in the picture) is blinking then you may have accidentally pressed the sync button on the bottom of the adapter or the mouse.
To fix this problem, press the sync button on the bottom of the adapter.
Next, press the sync button on the bottom of the mouse.
Mar 01, 2011 | Microsoft Wireless Mobile Mouse 3000
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
Picture Stutters on HD Channels
Hi my name is Roety,
I can help you with your issue ,
 Sounds like a bad signal issue , check it on other inputs to confirm
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 20, 2009 | Vizio GV52LF 52 in. LCD TV
1998 dodge caravan crank shaft or cam shaft sensor??
maybe have autozone or equal scan the computer for codes. could be a misfire in the cyl. somewhere. give me a code number and i will try to assist you further.
Nov 09, 2008 | 1998 Dodge Caravan
Samsung s730 Digital Camera - Video Stuttering Problem
I have the same problem with 640x320 video @ 30fps. The first one was very clean, but after that the video freezes every two seconds, but the audio don't. I "fixed" this issue changing the video format from NTSC to PAL. Now the videos are smooth again, and if you want NTSC playback, just use a video converter on your PC.
Jun 24, 2008 | Samsung Digimax S730 Digital Camera
My rio ce2100 keeps stuttering or skipping
I would recommend wiping your player - (if this doesn't work then it is probably the tracks/audio you are playing and not the player):
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Dec 08, 2006 | Rio CE2100 MP3 Player
Uniden BC246T Handheld Scanner Logo
111 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
