Question about Philips RC2573 Remote Control
32lc5dc lg tv stuck in hotel mode
Please help 32lc5dc stuck in hotel
mode
  • 3 Answers
It is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Posted on Feb 06, 2011
  • 2 more comments
  • Dave Crabb
    Dave Crabb Mar 15, 2017
    On the LG we bought from a hotel clearance it was locked out. Tried all sorts of fixes. Saw this link and also noticed a reset button on the back of the tv. The reset does not fix the tv. However when you remove the two screws holding the tv coax input card, pull down the card by the little handle and let it dangle, then press the reset button the tv became like a new factory tv with all functions.
    Screw the card back in and you are done!
  • Tammy Corbin
    Tammy Corbin Aug 13, 2017
    I love you!! Thank you
  • Pr3ttybyrd Sep 01, 2017
    Omg!!! Thanks so much!!!!
    I tried everything. Even called LG. They acted like I was a criminal!!!! I bought a TV from a hotel liquidation sale for $50.00. I thought I was ripped off!!!!!this totally worked!
  • 325 Answers
Press MENU for approx 5 seconds then enter, 1105 this will bring up the LG hidden menu then disable the hotel mode option.
Hope this helps
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
  • Christy Everett
    Christy Everett Apr 21, 2015
    Do you have to have original Remote control
    Habit-Forming:
  • 55 Answers
Still stuck. I held the menu for 5 seconds and didnt work with the 1105. i hit the menu button, and setup and the screen options are not available. is there a way to access these? Thanks.
Posted on Sep 30, 2009
    New Friend:
Idk what to do i took the card out of mine and it still wont let me us the hdmi ports
Posted on Jan 08, 2016
My 32lc5dc is in hotel mode and won't unlock I've tried everything
Its a long shot but if you could get into the menu, select lock and try code 1105 it might unlock it, it might not.
However, some hotel TV's have a different main pcb, to stop them be worth anything if stolen.
Aug 24, 2016 | Televison & Video
Stuck in hotel mode
The pin is 9876, ENTER. The zeros won't change while you input the code.
May 16, 2015 | LG 32LC5DC 32 in. LCD HDTV
I am at a hotel for a couple months. There is an lg 32lc5dc for a tv. There is no box to order movies but I can not use the hdmi port. There is audio but no video. The hdmi 2 port does not work at all...
probably the tv is hotel mode ,which is the management or tech have lock the sys ,to avoid complication for guest ,u have to find the manual or through on line.
Oct 05, 2013 | Televison & Video
Tv comeson no pix but sound.Turn off then back on then all is well,I work at a hotel with 100 of these tv's. They are all doing this. LG suspects the main board....on all of these tv's???
Actually call LG, they have a simple fix. They sent a team out to do urs. It is actually under that board there is a small, .5 inch hole with plastic in it. The melted that out with a soldering iron and then covered with a translucent dust cover that looked like a bandaid. I just burn the hole out and leave it if I get one. Crazy but true.
Sep 22, 2011 | LG 32LC5DC 32 in. LCD HDTV
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
I need to reset i dont know the code
please post it here if you do find it. thanks.
someone stated this
noavatar_s.gif Dish Fitter
Rank: Master
Rating: 70%, 17 votes
Press MENU for approx 5 seconds then enter, 1105 this will bring up the LG2.gif hidden menu then disable the hotel mode option.
Hope this helps
Cheers
Apr 06, 2009 | LG 32LC5DC 32 in. LCD HDTV
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Rgb input is dissabled
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Dec 12, 2008 | LG 32LC5DC 32 in. LCD HDTV
Philips RC2573 Remote Control Logo
12,767 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
