Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia LCD KDL32M3000 picture going dark
Picture was fine, has know turned dark, tried to adjust picture settings and nothing changed. Is this the backlight?
  • 1 more comment
  • lmerrick Jan 17, 2009
    Thanks lonestar, have picture very dark, audio good, there are shadow on any moving objects.
    Thanks lonestar, warranry expired, called customer support explained problem and what I thougt it might be (thanks to you) they told me to bring T.V to authorized repair dealer. Is this something I could fix on my own? If not do you have any idea of approx. cost.Thanks again
  • Jason Morris May 11, 2010
    Can you see a dark picture or nothing at all?
    Do you still have audio?
    Let me know and I can assist further. Lone99star
  • 362 Answers
Sounds like it may be the backlight ballast on the inverter. Hopefully you are still under warranty, Call customer support even if you are out of warranty and explain problem. In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
In Spanish: 1-800-222-7669 - Follow the (English) voice path for your product, and then select the option for Spanish support
Hours: Mon-Fri 9:00AM-10:00PM / Sat 10:30AM-7:15PM EST
If they can't help let me know and we can diagnose the problem together. Let me know if this helps and please rate this solution. LOne99star
Posted on Jan 17, 2009
  • Jason Morris Jan 17, 2009
    Hi lmerrick,
    I am going to provide you with a link to the best TV expert we have, the interface takes a minute to load but this guy has the service manuals and is very helpful.
    http://www.assistrepair.com/
    Tell him I sent you and he will take care of you.
    If he is not available keep trying he is usually there late.
    Lone99star
    Sergeant:
    Champion:
  • 431 Answers
The kdl models almost always have a bad lcd panel
Posted on Oct 02, 2010
Sony Brovia TV the picture went dark. You can see it but not to well.
Picture Become dark means there is some problem with the back light of the tv. can be problem with the back light led drive or the led array.
www.electro-medical.blogspot.com
Sep 06, 2015 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Panel issues with sony kdl-hx800
That sounds like a defective LCD panel tab connection. Does it go away if you tap the left side of the set? Or does it clear up when the set warms up?
Nov 27, 2012 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
682 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
