Question about Motorola Mobility HS850 Consumer Headset
CAN U HELP ME SET MY BLUE TOOTH UP? - Motorola Mobility HS850 Consumer Headset
  • 716 Answers
Close The Headset Boom And Hold The Multifuntion button until theheadset indicator turns on then release and open the boom. Then its OnDiscovery Mode And The Code Is 0000. Pairing IsSuccessful when the indicator on the headset flashes 10 times. The Light Being Onsteady is pairing mode.
Also Click Here For Your Manual
Please Rate Our Experts
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Posted on Jan 23, 2009
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
Set up for Blue Tooth
Please specify your phone make or model
Jan 17, 2014 | 2013 Toyota Venza
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
Jul 14, 2009 | Ranger TR-966 CB Radio
Can't set up blue tooth
Strangely enough I went to the website where I purchased the blue tooth. It recommended holding down the button for 8 seconds as opposed to the 3 or 4 listed in the manufacturer's instructions. When I did this it found my phone. The pairing worked fine and now so does the blue tooth.
Jan 15, 2009 | LG Vu CU920 Cellular Phone
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Need instructions to set up blue tooth in my phone
Yes, it would help if you gave the model number. However, if you do a google search for LG Rumor user manual, you should be able to find a download.
Jun 16, 2008 | Cell Phones
MY BLUE TOOTH ISN'T BEING READ BY MY PHONE...
Delete the headset from your phones previous or known devices and turn off phone then back on again and try pairing again. If still same could be faulty phone, but if you can try headset on somebody elses phone to rule out headset.
Jan 23, 2007 | Audiovox SMT5600 Smartphone
Motorola Mobility HS850 Consumer Headset Logo
51 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
