Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Aquarius Hotpoint WD640 is not spinning
Machine is not spinning or emptying water out of the drum.
    Problem Solver:
  • 5 Answers
Pump problems
Posted on Jan 17, 2009
SOURCE:
After a wash the water is not emptying out of the we64 aquariouse extra, hotpoint. how do i fix this? thank you
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Access to the sump of WMD960 Hotpoint washing machine
There is a lower removable cover at rear of washer,remove this, locate and remove large black hose fastened to drum, locate and remove filter inside hose to clean.
Please rate my solution.
Thanks.
Aug 29, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
270 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
