Question about Bunn GR10 Coffee Maker
Grounds splash from basket into carafe
In the last few months, after adding water and closing the lid to the reservoir (which starts the brewing), the grounds make a mess inside the basket. The grounds splash outside of the filter and cake on the inside of the basket, and a lot get into the coffee carafe. Any suggestions?
  • 1 more comment
  • wboese Nov 17, 2007
    I have the same problem, I have tried differnt ground coffee, bbut the I get real weak coffee. I have also tried differnt filters and poking a hole in paper filter.
    Suggestions?
  • Anonymous Nov 08, 2008
    I started having the same problem with grounds once I switched to decaf. Bunnomatic.com says decaf and soft water can cause this. I ordered a flow restrictor and I believe it is free. Its a sprayhead with less holes. Hopefully it works.
  • Anonymous Mar 16, 2014
    When I open the front, there are grounds all over the inside
In the paperwork that came with the Bunn, it said that Soft Water can be slow to move through the grounds and the filter. There was another scenario, but I don't remember it right away. If you can get a copy of the instruction manual they give a couple of suggestions and offer to provide (free of charge) a spray head that should help the situation.
Posted on Nov 02, 2007
Have you checked to see if the sprayhead is missing? One that we had at work did the same thing when the sprayhead fell off. Being that it was brown and blends in with the coffee grounds, it was thrown away with the old grounds. Replacing the sprayhead fixed the problem.
Posted on Jul 28, 2007
My brother has a Bunn that does the same. I think the coffee filters he is using are too short. If you think this might be the problem too, try an internet search for Bunn coffee filters. Hope this helps!
Posted on Jun 20, 2007
SOURCE:
We recently purchased a refurbished Cuisinart DGB-600 Coffee Maker at a yard sale. So far, we've had three batches of horrible coffee that tastes more like water with coffee flavoring. The first two...
It sounds like the water isn't flowing through the coffee grounds correctly. Perhaps you don't have the right kind of filter installed (either the right-sized paper filter, or the "gold" filter that comes with the machine) ... or, if uising pre-ground coffee, and if the coffee is all in a pile in the middle of the basket... the water will follow the path of least resistance, so much of it may run "downhill" and around the coffee, through the filter and into the carafe, without passing through the coffee. (That would be more likely if you're brewing only a few cups rather than a full pot.) Or, you might not be using enough coffee; I would use about 7-8 tablespoons of ground coffee for 10 cups of water. I'd recommend getting it working properly with pre-ground coffee before trying the grinder. It's also important that the lid of the carafe is in place while brewing, and that the carafe is fully seated in its chamber; the bump on top of the carafe's lid triggers a spring-loaded mechansim on the bottom of the basket, which regulates the flow of water into the carafe... so if any parts of this system aren't lined-up right, you may get unexpected results (including, in some cases, water all over the countertop).
I also recall, once upon a time, using one of those pre-packaged "packets" of coffee... sort-of like a large tea bag full of coffee grounds... and getting unsatisfactory results; again, the water found it easier to run over/around the coffee packet, rather than through it.
Oct 10, 2010 | Cuisinart DGB-600 Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
Aug 19, 2009 | Coffee Makers & Espresso Machines
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
As coffee brews it spills out everywhere. At first if I made minor adjustments to where the pot positioned under the filter it would help, but it seems to be getting worse. I can't make a pot of coffee...
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Cuisinart brew on demand coffee maker
what about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
Aug 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Bunn GR10 Coffee Maker Logo
126 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
