Question about Vehicle Parts & Accessories
2002 Jeep Grand Cherokee Alarm/Remote start
Hello!
I am trying to install a Viper 5901 alarm and remote start with the Xpresskit XK531 transponder bypass. I need a wiring diagram explaining where the correct wires are and what colors they are. Any help would help.
Thank you
  • Anonymous Mar 28, 2014
    Xpresskit dball2 or xpresskit pkall
The12volt.com has wiring diagrams for most vehicles. Including yours
Posted on Apr 10, 2009
    Sergeant:
  • 227 Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Cant start car with key
It sounds like you might be having an issue with the transponder or "chip" in that key. When you turn the key and it doesn't start you probably see a flashing key icon on the dash with a circle and a line through it. When you remote start the car it is using a by pass module to trick the car into thinking you have a valid transponder key in the ignition when it starts up. Go to a locksmith and have another key cut and programmed to the car.
Jan 29, 2014 | 5901 Security Remote Start System
Viper 5701 not remote starting or unlocking
It's possible that you may have inadvertently locked the remote. Press "F" then unlock to unlock the remote. Then attempt to send your command.
Oct 15, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
It starts and runs, than shuts off 3 seconds later? i havent tried anything yet, and it was installed in 2002. jeep grand cherokee.
Do you have anti-theft system bypass module installed? Transponder key bypass? Try unlocking the doors with your factory Jeep remote (turns off alarm) and leaving the gray transponder key in the ignition cylinder. Then try activating your remote start. Sounds like one of the factory anti-theft systems is still active. Basically if the car's computer doesn't want it to run, the car won't run. You have to fool the car into thinking it is OK to start and stay running without the key and anti-theft device deactivated. You need to leave a transponder key in the vehicle under the dash to bypass that system. You can get a generic one for about $20. You MUST have 2 original gray transponder keys in order to program a third. There is a sequence of putting one key in the ignition, then the second, then the new blank key so the cars computer knows to allow that key also. If you do not have 2 original keys, then you need to go to someone that can program properly like dealership or some locksmiths or alarm shops. Then they usually charge about $100 for a second key. You don't have to have the key cut. That way if someone finds the spare transponder key in the vehicle, it wont turn the ignition cylinder. The anti-theft bypass module (factory alarm bypass) runs about $25. Bulldog Security or JBS model 791 should work for your vehicle. If you live in an area where car thefts are common, you may not want to bypass these factory security measures.
Hope this information helps.
Nov 02, 2010 | Prestige Remote Start
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
I have a viper 5901 installed on my 2008 Impala SS and every now and then the alarm goes off saying the doors are open but they are closed. why would this happen
This is happening because they used the cars domelight to set the alarm off when the doors are opened. When the cars computer goes into battery save mode and shuts down certain parts of the car, the domelight is one of them and a slight ground or 12 volt positive is backfed to the alarm and sets it off. This usually happens after 30 minutes. they should take the alarms door trigger and actually go to the cars door latch wires. The colors are:
gray/black - driver door tan/white - pass door lt. blue/black - back driver door lt. green/black - passenger back door
Aug 31, 2010 | 5901 Security Remote Start System
Hello, I have a Viper 5701 in Mazda 3 2006 several times my car car did not start when I crank it, absolutely nothing happens. The same thing happens if I open my car with factory remote and try to crack...
What type of transponder bypass was used? You will need to check with your installer. You will want to know if the data bypass module is coming ON upon remote starting. And NOT coming on during regular starting.
Aug 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
1,301 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
