Question about Sceptre X9G-NagaIV 19" LCD Monitor
Dell Monitor comes on but no picture
The monitor flashes the Dell logo then goes to black. My power button also goes from the blue color signaling "on" to orange within seconds.
What gives??
    President:
  • 2,992 Answers
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Posted on Jan 17, 2009
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Monitor is black,power line flashing.
Flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the viewsonic logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Aug 15, 2010 | ViewSonic VX924 19" LCD Monitor
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Monitor screen begins as computer is booting up and then screen goes black. Message says there is no signal.
If the power light dims or changes color after the no signal message comes up, that means the monitor went to sleep.
While the monitor is plugged in and on and the computer is also on, Try unplugging the VGA cable from the monitor. wait 30 seconds and then plug it back in o see if the power button light comes back to normal color and the screen flashes on.
If not, then the monitor is not getting a signal from the computer.
If using a desktop computer,Try a different cord or try the monitor on another computer.
If using a laptop, you need to activate the laptop to use an external monitor. That can be done through the display settings, OR, most laptops have a shortcut key feature which usually involves pushing the Fn key and one of the F keys at the same time. The F key may say CRT/lcd or have a picture of a monitor and a screen.
If the power light does light back up and still no picture, There may be an internal issue on the monitor
Nov 17, 2009 | ViewSonic VG2230WM LCD Monitor
Monitor blue light comes on shows emachines logo and color bars then monitor turns off and light turns yellow
your monitor is beleiving it is not receiving any signal from your pc. 1 make sure your cables are secure. 2 make sure your pc is on. 3 borrow a monitor from a freind to see if your pc is sending the signal out, if the borrowewed monitor is showing a picture, hook yours back up. 4 if still not picture your mpcb or video pcb in the monitor is bad.
Oct 28, 2009 | E-Machines eMachines Monitor E15T4
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
Goes out
Please list the model number of your monitor.
Also is the power light flashing? What color(s)?
Unfortunately the symptoms you are describing tell me the inverter/power board inside your monitor needs to be replaced.
Mar 05, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Sceptre X9G-NagaIV 19" LCD Monitor Logo
186 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
