Televison & Video Logo
Andy O Posted on Dec 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KV-x2162u lost remote
Lost the remote to the above tv. How can I access the menu to adjust picture settings?
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Dec 26, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15001347
Points
237762
To access the picture settings menu, you must have a remote control. There is no Menu button on the front of this TV to select inputs.
5 Related Answers
Anonymous
  • 275 Answers
  • Posted on Sep 18, 2006
SOURCE: sony kv-32s26 32 inch tv
Could also be faulty Power supply. If Proper 110 V is not generetaed by SMPS, the above symptoms appear.
Anonymous
  • 4234 Answers
  • Posted on Jul 18, 2008
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Anonymous
  • Posted on Nov 19, 2008
SOURCE: tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Anonymous
  • 103 Answers
  • Posted on Apr 06, 2010
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
I have a hitachi flat screen and have lost the remote in a move. When I turn the TV on, the picture doesn't take up the whole screen and I can't figure out how to fix it. Help?
You should be able to access the menu feature via the on TV buttons. Navigate to set up and adjust the presentation to your liking. The aspect is probably off.
1helpful
2answers
Lost remote for dp32649 sanyo and cant adjust pix shape with universal remote, nor is there settings on menu.
Pull up the menu. Go to the Picture Menu. Click Manual. Then go to Detailed Sertings. Once there, scroll down to the V-size & H-size to adjust them to your desired settings.
I've lost the remote for my Sony KV-2095R TV and I would like to be able to use the auto-scan or add/remove functions to program the TV channels. These functions were on the remote and as far as I can...
There is substitute remote available for KV-2095R in remotes.com
Original remote is no longer anywhere, click above link for price info and online order.
I'm afraid, no other way to manage channels directly in tv menu, remote is necessary to do that.
Thanks.
2answers
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
3helpful
NO REMOTE
Hi there. The actual button option that you will need to use for this adjustment will be the aspect button and, unfortunately, this button is only on the remote and not on the TV itself. If there is a control panel located on one of the sides of this set, you may be able to push the menu button here and navigate your way threw the menus screen to the aspect option. I suspect you will need the remote.
please rate and God bless..
KV-36XBR450 CANNOT ADJUST COLOR
This sounds like you might of lost one of the colors of the crt. I would suggest that you take to a repair shop.
Lost remote control
I have been there with my KV-27S42 and lost the remote. I bought one from Replacement Remotes.com, it doesn't look exactly like the other one (a couple years ago the replacement DID look like the Sony and they must have been threatened) so now it looks a little different but is an equivalet and will solve your problem for $18.
Here's the link:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=1473&categoryid=88
Now my trouble is my KV-27S42 quit working YESTERDAY and I think it's going to cost more than it's worth. May have to abandon Sony because I read about a lot of failures.
Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
2answers
Zenith wont tune channels
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
