Question about Toshiba Satellite P100 Notebook
The three inputs/outputs on the front of mt satilite p100 toshiba ,whats the third one for??
  • 2 more comments
  • noelwalsh Jan 17, 2009
    bubbabear there the 3.5 stereo jacks on the front?one is for head phones the other is for a mic but what is the other one for????,i am wondering is it a second channel on the motherboard sound card???? would you know.noelwalsh@hoymail.com
    yea! a little musical note
    toshiba p100 160, model number ;pspaae-01dooven, thanks bubbabear! if its a second channel for the sound card it would be great ,thats exactly what i want it be! i use a program called vertual Dj .
  • noelwalsh Jan 18, 2009
    sorry chief thats the only number on mine
  • Toshiba Master
  • 2,794 Answers
Toshibas have an output for using an tv through composite output. It requires a special cable with a mini jack on one end and three rca male ends on the other. The yellow one for video and the red and white ones for audio.
Posted on Jan 16, 2009
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jan 17, 2009
    If it's a third mini jack it could be the composite output jack. My Toshiba is configured that way. Is there an icon next to the jack?
  • Tim Babcock
    Whats the complete model number of the unit (based on the label on the bottom of your computer)? I'll look it up on the support website.
  • Tim Babcock
    After the P100 there should be a number that starts with ST on the lablel. It contains four digits.
  • Tim Babcock
    Tim Babcock Jan 18, 2009
    Try going into the control panel and look under system. Does it give you a better model number in there?
Power supply dead
it's encouragin! I got the same issue this night with my oe .. and here I don't see answers ...
Nov 17, 2013 | Behringer XENYX XL1600 Live Mixer
Toshiba satilite series will not bootup. three long beeps,3 more long bips one short. what is this saying?
in my experience with this type of issue it can mean your hard drive is dead or something is wrong with your RAM if you have a spare hard drive on hand and ram replace the hard drive and ram and see if it fixes your problem
Jan 01, 2011 | Computers & Internet
Where can i get manual for toshiba satillite p100-240
online look it up on google !!! it's your best friend for all or just about any answer you might have ok:
type this in the search pane ok
(manual for toshiba satillite p100-240)
and you should be able to find one ok good luck and have a nice day the fixist !!!
Aug 02, 2010 | Toshiba Satellite P100 Notebook
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
Need part number for Toshiba Satilite computer. Have serial numbe
What you need is the model no. You can then go to the toshiba site and put that in and it will list you the various categories of parts with the part number.
Jan 20, 2010 | Toshiba Satellite L505-S5966 Notebook
I have the same preoblem...need manual
Manuals are available for printout in PDF format from the manufacturer, or with a password through devicemanuals.com
As I said in a post to another person, make sure that you're routing the TV signal into or through the VCR. If it's from Cable/Satellite or Digital Converter box, it will simply need to be routed with a coaxial cable, it's a simple fiberoptic cable with a copper or gold prong that you screw onto the back. If you're unable to do this, the box for your broadcast/satellite/cable should have a three-way output, color-coded white, red, and yellow. The red and white are for stereo sound, and the yellow is for the video signal. You can route that output into the three-way input on the back or front of the VCR. This can be technically more challenging, depending on how it needs to have the input setup, for instance needing to be on a specific channel, but routing the cable through the input and output for the VCR is the simple way, and should give you no trouble.
Sep 16, 2009 | Toshiba W522 VHS VCR
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
Open Questions:
Toshiba Satellite P100 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
