Question about Maytag Neptune MAH5500B Front Load Washer
How do i get the machine to drain the water out.
A piece of clothing was stuck in the door and we opened the door because the water was already gushing out of the bottom door. Noiw I am trying to get the machine to drain the rest of the water.
    Genius:
  • 2,920 Answers
You will need to run it through its cycles to get it to drain.
Posted on Jan 17, 2009
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
Water not draining my ge washer will ot drain the water. it is spinning but not draining. i took out all the clothes and set it to spin and drain but it wont drain the water. what to do? can i do it...
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Washer stopped cloths stuck in washed as the door won't open
if there is water in the machine you can use a wet dry shop vac and aatch it to the end of the drain hose and remove the water once the water is removed the door should open.
then you need to make sure that there is not restrictions with the drain pump or hoses
Jun 06, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I have an Electrolux EW 548 F Washing machine. It stopped while in a cycle and it won't continue or let me open the door to get the clothes out.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
May 03, 2010 | Electrolux Washing Machines
Door wont open laundry stuck in there now since Friday night...This product S-----!! NOT TO MENTION ALL THE MOLD ISSUES ALREADY...
you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
if the water comes out fairly rapidly you may need to replace the drain pump.
once the water has been removed you can open the door and remove the clothes.after everything is removed you need to remove both the hoses from the drain pump and look in it for any thing that will stop it from turning and or blocking the drain pump.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water won't drain
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Good Luck!!
Thanks
Jul 07, 2009 | Frigidaire Washing Machines
WASHING MACHINE BLOCKAGE
It won't drain If your washer won't drain, check these:
It doesn't spin or pump
It pumps, but the water returns
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 02, 2009 | Miele Novotronic Premier 500 Front Load...
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
