Question about British Telecom VAIO® VGN-BX740P PC Notebook
Sony Vai BX740P, adding memory
Hello:
My laptop can wtih 1GB os installed memory.
I brought 2 2GM memory DDRII667 PC2-5300
so-dimm cards to upgrade to 4GB.
PROBLEM: after opening the memory slot on the backof the laptop, there i no memory card installed.
Where is the 1GB?
Thanks
Aan
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Memory stick upgrade 2 512, 2 1GB what order do I put them in
On the motherboard they should be labeled as to which slot is Dimm 1, Dimm 2, Dimm 3 and Dimm 4. Put the larger ones (1GB) in Dimm 1 and Dimm 2. The smaller ones (512MB) in Dimm 3 and Dimm 4.
May 06, 2012 | Sony PCV-RS620G PC Desktop
I have a lenova 9704-A36 pc with vista installed came with 1gb of ram. Want to upgrade, where to find compatible memory
52757437-260x260-0-0_lenovo+2gb+pc3+8500+1067mhz+ddr3+ecc+sdram+memory.jpg Mouseover to zoom or click to enlarge Lenovo DDR3 2 GB SDRAM (41U5252) $57.00 1 store
  • Technology: SDRAM
  • Form Factor: DIMM 240-pin
  • Capacity: 2 GB
  • Modules Qty: 1
  • Bus Clock: 1066 MHz
ahr0cdovl3d3dy5jb21wdxrlcnnzywxllmnvbs5hds9zag93aw1hz2uucghwp3byb2r1y3q9mtaznzgmaw1hz2u9mcz0exblpwxhcmdl==.jpg
Lenovo 1GB DDR3-1066 Memory Module for Notebooks
Improve overall performance of ThinkPad systems by upgrading with additional memory. PC3-8500 DDR3-1066 low-halogen SODIMM memory offers maximum data transfer rates up to 1066MB/sec(1) to help you increased performance of memory intensive applications such as streaming video, graphics and CAD programs. Adding more system memory is one of the least expensive ways to help boost overall notebook system performance and allows more multitasking which saves time and hassle.
May 02, 2012 | Lenovo Computers & Internet
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
How to upgrade the memory and what is the Maximum available memory card for this unit?
Okay, the maximum memory you can install is 1GB.
However, you either have 256mb or 512mb soldered on to the motherboard already, so check this out before buying.
The memory type is: 200 Pin SO DIMM DDR2100 266MHz
Aug 21, 2010 | Panasonic Toughbook CF-73 Notebook
I have a Sony Vaio PCG-K25 laptop and am trying to upgrade to a gig of memory. Is it possible to do this? I put 2 512 memory chips in the slots but it only sees 448. Using Kingston Technology 512 mb...
This laptop has its own graphics card that doesn't rely on system memory for the graphics.
There should be no reason why its not detecting all 1GB of ram that you have installed.
Open the ram cover and make sure that you have clipped the ram into place properly.
Regards.
Jul 01, 2010 | Sony VAIO PCG-K25 Notebook
I want to upgrade the ram in my IBM thinkpad R52 laptop. Do I have to buy DDR1 or DDR2?
You have to buy DDR2. The compatible memory is DDR2-533 PC2-4200, 200p SODIMM, 1.8v
To install the memory, follow these steps:
  1. Turn off the system; then disconnect the ac adapter and all cables from the system.
  2. Close the system display, and turn it over.
  3. Remove the battery.
  4. Loosen the screw on the memory slot cover; then remove the cover.
    If the SO-DIMM is already in the memory slot, remove it to make roomfor the new one by pressing out on the latches on both edges of thesocket at the same time. Be sure to save it for future use.
  5. Find the notch on the side of the SO-DIMM.
    Note: To avoid damaging the SO-DIMM, do not touch its contact edge.
  6. Withthe notched end of the SO-DIMM toward the right side of the socket,insert the SO-DIMM into the socket at an angle of about 20 degrees (1);then press it firmly (2).
  7. Pivot the SO-DIMM downward until it snaps into place.
  8. Make sure that the card is firmly fixed in the slot and does not move easily.
  9. Replace the memory slot cover by aligning the back side of the cover first and then tightening the screw.
    Note:When you have added or upgraded a memory card, do not use your systemuntil you have closed the cover. Never use the system with the coveropen.
  10. Put the battery back in place, turn the system over again, and reconnect the cables.
To make sure that the SO-DIMM is installed correctly, do as follows:
  1. Turn the system on.
  2. Whilethe "To interrupt normal startup, press the blue Access IBM button"message is displayed at the lower-left of the screen, press Access IBMbutton.
  3. Select Start setup utility.
  4. The BIOS Setup Utility screen appears. The "Installed memory" item shows the total amount of memory installed in your system.
    For example, if your system has 256 MB of memory and you install a256-MB SO-DIMM in it, the quantity shown in "Installed memory" shouldbe 512 MB.
The compatible memory can be purchased here online.
Nov 27, 2009 | IBM ThinkPad R52 Notebook
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
British Telecom VAIO® VGN-BX740P PC Notebook Logo
78 people viewed this question
Top British Telecom Computers & Internet Experts
David Payne
David Payne
Are you a British Telecom Computer and Internet Expert? Answer questions, earn points and help others
