Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak AiO home Center will not open
My printer is printing very light and sometimes not all of the materials. In checking around for a problem it tells me to clean my printer heads. I tried to open the Kodak AiO home center window and it will not open My Printer is the kodak ESP3 All-in-one printer. It's prints great quality hoever I can't open the software that goes with it. When I click on it, it takes forever to get the program to respond when it finally does it's just an empty window that has the header Kodak AiO Home Software. How do I get the program to open correctly?
    Problem Solver:
  • 5 Answers
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Posted on Jan 17, 2009
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How important is downloading kodak home centre software for the kodak printer to work?
Kodak AiO home center, serve as a driver as well for your printer to print from the computer. It will let you scan, copy or print pictures. AIO home center will let you select the settings you want for your printer
Sep 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
AiO home center wont open up
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on print pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Jun 30, 2009 | Kodak ESP 5 Printer
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak easyshare 5300 aio printer
i CANT OPEN MY AIO HOME CENTER WITHOUT GETTING AN ERROR THAT SAYS ENCOUNTERED A PROBLEM, HAS TO CLOSE. ALSO, MY PICTURES ARE NOT VIBRANT COLORS.
Jul 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Video display with Kodak AiO Home Center
Make sure that your screen resolution is 1024x768
Jun 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
If you can open the home center trying going through your printers and faxes in your computers control panel. That's what I did. Just right click on your printer and select preferences. Go to advanced and click on maintenance. You should have two options, to calibrate or clean your print heads.
I did both with mine and it still doesn't print, but who knows, maybe it will work for you.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
460 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
