Question about Samsung Digimax S730 Digital Camera
Lexar Platinum II 4GB sd card won't work on my Polaroid PDC 3070
I have a Lexar Platinum II 4 GB sd card, and in most cameras, it says "SD CARD ERROR". In my Polaroid PDC 3070 camera, when it says "POLAROID" it freezes up. Can you help me?
  • 1 more comment
  • paultheman Jan 17, 2009
    Sorry I that was an accident.
  • Anonymous Mar 22, 2014
    when i turn camera on it says card error
    what type of sd card do i need?
  • 33 Answers
That card is not compatible with that camera. It's too large for an older model like that. Backup the card's contents and format it. It should work in newer models but probably not the PDC 3070.
Posted on Jul 29, 2009
My alcatel one touch fiery wont recognize my 4gb sd memory card so What can I do
Sad to say, you may have to buy another brand SD card, my camera can't recognize Kingston 8 GB card but but recognize Lexar 8 GB card. Good luck.
Apr 05, 2014 | Electronics - Others
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
What kind of memory card do I use
You may use any SD card up to 2GB in size (4GB if you can find any). Make sure you get an SD card and not an SDHC card, as the latter are electronically incompatible and will not work. The brand and speed won't make much difference, though a faster card may download faster to your computer if you use a compatible card reader. I'd also stick with the major brands, such as SanDisk, PNY, and Lexar.
Mar 01, 2013 | Polaroid T831 Digital Camera
If my JVC-GRHD1 won't record on an SD card which type of card do I need?
This camcorder will use SD cards. However it will not use SDHC cards such as your 16GB Lexar card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 19, 2012 | JVC GR-HD1 Mini DV Digital Camcorder
Check card protect switch when i insert memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 12, 2011 | Polaroid PhotoMax PDC 3070 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Want to use 4GB sd card in Polaroid i832 but all the specs says it only accepts UP TO 1 GB sd cards. Will it recognize picture images on the extra 3 GB or only on the first GB.
A 4GB card is known as an SDHC card...probably not accepted by your camera. Stick with the manufacturer's recommendations. You could go to the support section of Polaroid's website to see if they have a download for your camera model that would permit the larger card.
Sep 02, 2009 | Polaroid i832 Digital Camera
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Aug 31, 2009 | Moultrie MFH-DGS-200 Digital Camera
Problem
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 03, 2008 | Polaroid PhotoMax PDC 3070 Digital Camera
Samsung Digimax S730 Digital Camera Logo
217 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
