Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Need a new screen and protection screen for Mits ws 55513 where can i get one or is it cheaper to buy a new tv
  • darindifeo Jan 17, 2009
    this 55inch tv still works great i just need to replace the screen. Is their any websites that sell them?
Wow I cannot believe the estimates for the screens of this model and other Mitsubishi TV. I bought one about a year ago. It cost me $55.00. A far cry from the cost of the TV or anything else.
By the way. I got this direct from Mitsubishi. Got it in 5 days and the shipping was $16.00.
Thought you might be more inclined to do this with the actual price.
I am looking for the instruction but I was told that you loosen the front screw lift up and take out the screen being careful not to mark the other screens, (I guess there are three at least). SO the biggest issue I can see is the fingerprints or marring of the other screens.
Hope this helps but at least it should make you feel better about fixing and replacing the screen.
Posted on Jan 26, 2009
    Genius:
  • 2,920 Answers
It would almost be cheaper to buy a new tv the screen for a 55 inch would run about 400.00 possibly more. i know because i tried to buy one a couple years ago and ended up getting rid of the tv.
Posted on Jan 16, 2009
    Champion:
  • 453 Answers
The only solution u have is to call all tv repair shop and see if they have a use screen with the same model ,
I have a Mits WS-65511 that the picture lighting started to to fade in and out. We still have sound but the picture is not the right color, fussy and lighting is dim. I did reset the TV, no difference. I...
Three basic color picture tubes in tv are getting weak in performance and requires more current to work properly. There is Screen voltage settings that needs adjustment for each picture tube in tv.
Let me know are you familiar with electronics stuff repair and willing to work in live tv?
Thanks.
Jul 03, 2011 | Mitsubishi WS-55513 55" Rear Projection...
TV won't turn on with remote or power button
if it is completely dead, then it could be a micro lock up.
take of speaker grille
open front panel with screwdriver
find DZ connector that goes to the buttons
unhook that connection and plug the tv back in
wait 2 minutes
the tv may now work with the remote, the buttons are bad, common mits issue.
if this doesnt solve, or you have flashing leds, let me know.
May 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a 55in mitsubshi flat screen tv WD 57825, the timer light flashes but the screen won't come on. What do i do
never buy another Mitsubishi again, it's sad that everybody has the same problems, you pay for a high end tv and i've had more problems with it than any other tv
Jun 26, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Law suit
Easy repair = www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three fuses on trace side of DM board...........T.
Apr 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws 55513 rear projection HDTV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Aug 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
