Question about Ariens Garden
Heavy Smoke on Start-up & Primer Bulb Prob.
Ariens snow blower; Smokes very heavy on every start-up. Oil level is fine. Started after tipping it onto its front per repair maual to grease underside fittings. Smokes for about 5 seconds then clears out.
Also the primer bulb doesn't seem to do anything, but if I disconnect the tube from the carb. it pushes air fine.
  • Mike Rice Jan 19, 2009
    Didn't help the problem. The bulb doesn't seem to work when the tube is connected to the carb. It only works when disconnected. The plug seems to be fine.
2 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: very heavy smoke on start-up & primer bulb prob.
It should be fine, it's just some oil that seeped through and is now in the muffler. Just let it run for a while to burn off what is in the muffler you may also have a little bit in the carb, if you want to check the carb just pull the bowl off to see if there is any thing for oil in there, be sure to shut the fuel off or clamp it off with needle nose vise grips before you pull the bowl off. Otherwise everything will be ok just run it for a while and keep an eye on the oil level.
Posted on Jan 17, 2009
Where can I get step-by-step instructions for starting an unidentified snow blower.
If it was left with gas in it. Take the carburetor off and clean it even before attempting to start.
Then the procedure is common. Full Choke, half throttle, two presses on the Primer bulb and pull cord
Jan 30, 2016 | Garden
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
I have a 1996 Ariens ST-24 snowblower that is hard starting. When it does start it runs just fine. The Tecumseh engine has a primer and I run synthetic oil, 5W30 Mobil 1 and use non-oxy gas with Sea
You could have a hole you cant see in the primer or line to the carb. They vibrate and rub. Make sure you DONT use eco gas. This will turn your gaskets to trash in one summer of not using it. Lastly dump out the old gas and start with new. Snow blowers are famous for condensation building in the tank. Hope I helped
Jan 13, 2015 | Cars & Trucks
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
My 1969 triumph spitfire has been running fine but lately has started suddenly cutting out and losing power under heavy uphill loads. When this happens it always blows oil and smoke out aroumd the bol
time to rebuild motor or replace it. The smoke your seeing is pressure from the cylinder escaping around the piston rings into the crankcase and venting out the covers
Aug 24, 2014 | Cars & Trucks
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
The blower won't throw snow - especially heavy snow. Auger and impeller turn but bog down. Trying to replace belts, but there are no numbers or sizes on them. Are these generally available (say at a...
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
Feb 01, 2011 | Garden
SMOKES WHEN STARTING UP SOMETIMES
If it is blue smoke, it is oil burning. If it only smokes after sitting, then it is a leaking valve guide(s). If it smokes randomly while running, you have leaking oil control piston ring(s). If the smoke is very heavy and white, that is coolant and your head gasket is the problem.
Mar 04, 2010 | 1999 Cadillac DeVille
Very heavy smoke on start-up & primer bulb prob.
Jan 16, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
159 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
