Home | Sony | SDM-HS73P (Black, Silver) 17" LCD Monitor | Black screen flashes aft...
Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
Black screen flashes after initial power up
By squid_750 on Jan 16, 2009
push the on/off button and you can see the normal screen and goes black again. There was a electrical burning smell at the time when the problem first started.
Solution #1
posted on Jan 17, 2009
Not Rated)
Richard_La
Rank: Apprentice
Rating: 0%, 0 votes
Possibly the backlights have failed. The screen part may be working normally. Get a bright light close to the front of the screen, see correct image faintly. Commonly it is failure of the high voltage inverter circuits that power the backlight fluorescent lamps. You can probably buy replacement circuit or repair the one you have. I have done this on another model. You need to search the web for experience of the same model. RDL.
Was this helpful?
Yes
No
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SDM-HS73P 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
