Question about Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive
Maxtor One Touch 4 is beeping when I connect it by usb
It even won't recognize it when I plug it in. nothing happens.
The light comes on but it starts beeping
  • 298 Answers
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Posted on Jan 17, 2009
My computer stopped recognizing my seagate
same thing happened with me, Looks like your pc usb slot is not providing enough power to the drive wither use a Y - USB cable (comes with three USB ends ; where in you will insert two USB cable ends to two usb ports on your pc and the other to ur hard disk) or buy a powered USB root hub.
Mash
Oct 18, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxator hard drive not being recognized
Well all good things must end and it sounds like this one has. If it doesn't connect in either computer then something inside has either been bumped loose or it's broken.
Sep 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Something Dopped on maxtor 500G, Now not reading - making beep
two thing could be the power supply in the external box or it could be the drive it self
go to maxtor.com and download the software to test the drive
Aug 11, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Is this a new drive or have you been using it for some time and it just started doing this? What make/model computer do you have?
Usually when they start beeping like that, it's an indication that the drive is not getting enough power. It's possible that you are plugging into unpowered USB ports. Try using the USB ports that are directly connected to the motherboard (the ones in the back.)
Use USB 2.x ports if they are available. Try connecting the drive to another computer.
Jan 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor One Touch 4 500 GB External Hard Drive (Windows XP (SP2) - I have an issue with my harddrive, where when I plug it into the USB, initially the power light comes on & beeps but it is not showing...
Had same problem. I shut down computer and restarted and Maxtor was installed and had desktop icon and everything worked then. I then backed up with no problems.
Apr 14, 2008 | Computers & Internet
Maxtor one touch III 500g, got knocked over and now when its switched on it just beeps at me, and nothing appears to happen. I can't see any damage but it's certainly not working.
First things first;
hello
1) verify the connection
2) you have to change the Disk on another USB port 2.0
3) if you got warranty I suggest you change the device.** if apply.
good luck
Mar 21, 2008 | Computers & Internet
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive Logo
554 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
