Question about Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine
How do I install my invisible zipper foot?
I ordered an invisible zipper foot for my Kenmore 385.16221. Since my machine is fairly new, I got one from the Sears site: part #97719. It is listed as a Kenmore Concealed Zipper Foot for Vertical and Horizontal Sewing machines.I cannot figure out how this fits on my machine. Since it is not a snap-on foot, I can't seem to figure it out. Naturally it came without instructions. I would appreciate any help.Thank you!
  • 1 more comment
  • purselady Jan 17, 2009
    I figured it out after HOURS! I needed to completely remove my my foot holder and use the thumb screw to tighten the invisible zipper foot. Once I got it on, it made more sense. Now, someone inform Kenmore that they need instructions when sending parts!
  • hunniapple Mar 11, 2009
    OK so I hav the same sewing machine and same problem, and just can't get what you did with the thumb screw to make the foot work!!!
5 Suggested Answers
jmgldsmth
  • 1869 Answers
SOURCE: Proper invisible zipper foot attachment for Featherweight ii 117?
www.singerco.com
Posted on Apr 29, 2009
guru_dev
  • 315 Answers
SOURCE: Sewing machine spares
you can get it from:
http://cgi.ebay.com/Zipper-foot-foot-for-Janome-sewing-machines_W0QQitemZ120415026103QQcmdZViewItem
Posted on May 12, 2009
  • 19 Answers
SOURCE: i need instructions on how to use a concealed
www.janomestuff.com has it all
Posted on Sep 16, 2009
  • 33 Answers
SOURCE: invisible zipper how to pit it in a skirt or what
First of all what kind of machine do you have? My machine has a foot for invisible zippers - if your machine
is older - they sell a package of feet to use for invisible
zippers. The feet are by Coats and Clarks and can be
found near the invisible zippers in your fabric store.
Inside the package you will find instructions on how
to put an invisible zipper in. If you have any problem
google "how to put an invisible zipper in " and you will probably find several to choose from . Good luck.
Posted on Feb 12, 2010
  • 1788 Answers
SOURCE: I bought a walking foot
I think it depends on your shank and everything I see on your model says low shank not high. I would double check that, a vertical is one that the bobbin does not just drop in, you open the front & take out the case and put your bobbin in and a horizontal is the one that you just open the the plastic slide on top of your machine and put it in. Take your manual in with you to Sears and let them help you get the right one.
Posted on Oct 05, 2010
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
Using an invisible zip foot my machine jams after a few stitches. It doesn't jam with any other foot, and when I sewed with the foot on a scrap of fabric with no zip as a test
Make sure that the needle is not too close to the zipper coils. Also, that the needle is not hitting part of the presser foot. Sounds like the needle is most likely encountering the zipper coils which are deflecting the needle. Move the coil further away from the needle.
Sep 04, 2016 | Sewing Machines
Have lost the zipper foot for a pfaff hobbymatic 939 The instruction manual I got with the machine is for a hobbymatic 947 and it looks exactly so I'm guessing the zipper foot would be the same. where...
You should be able to buy another foot, but you'll need to know if it is a high shank or a clip on style. Try this link to www.sewingpartsonline.com http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx they have two invisible zipper feet and two clip on ones. Don't mention your model but you should be able to email and ask if you aren't sure. I'd expect that the feet would be interchangeable between the models in the same era as yours. Just ignore the long funny shaped feet, they are for Pfaff sergers.
Oct 07, 2011 | PfaFF Creative 7570
Got bernina 1015 sport sewing machinewith one foot want to buy zip,buttonhole &overlock foot is ther a special number or do all bernina feet fit al types of bernina machines
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Jul 24, 2011 | Sewing Machines
Have brother sewing machine sc9500. Need invisible zipper foot. Don't know which kind to get.
My invisible zipper foot is a plastic generic one which was describd as being "low shank" and it works fine on three different Elnas I own.
I would have thought your machine was a low shank style too, there is a fair bit of similarity between feet with low shank clip on style. So if your feet clip on and off the shank, then you should be able to clip on another type of foot too.
if you try this link http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
then go through to the page for the foot attachment system that looks like yours you might be able to establish which one you need. THere is a brother high shank invisble foot listed, and an alternative part number. I jcan't see a Brother SC9500 machine listed so you might need to do a bit of elimination.
You could also email sewingpartsonline.com and ask them to help you identify the right foot.
Jul 12, 2011 | Brother Sewing Machines
How to sew in a zip? with Empisal dress maker 270
Sewing in a zipper is a fairly easy process, though a bit hard to explain in words :) You need an iron, pins and a zipper foot for your machine. The zipper foot allows the needle to get close enough to the teeth of the zipper without the foot getting hung up by the teeth.
The best thing to do in order to understand the process if you've never done one before is to look a a video on youtube and watch how a zipper is put in. Here is one link that shows how to insert a zipper http://www.youtube.com/watch?v=ue5z2rWS588&feature=related ...but there are several others too. Some show specifically "invisible zippers", some show side seam zippers and others show how to put one in where you have a waste band. When you get to the link above look to the right side of the page where you will see other videos to pick from too.
There are lots of interesting sewing videos on youtube. You'll note that though the process is basically the same different seamstresses have different tricks for getting a straight and tidy looking zipper.
May 16, 2011 | Sewing Machines
Invisible zipper how to pit it in a skirt or what foot do i use?
Feb 12, 2010 | Sewing Machines
Kenmore sewing machine and zipper foot attachment
refer to site feedback@sewconsult.com
Dec 14, 2009 | Sewing Machines
How do I attach the zipper foot? thanks!
Here is a website link that has picture illustrations of how to sew in a standard zipper, using both the centered and lapped methods, as well as how to insert the popular invisible zipper.
http://www.threadsmagazine.com/item/3728/sewing-in-a-zipper
Hope this helps.
Sep 15, 2009 | Brother Sewing Machines
Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine Logo
953 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
