Question about Roxio Easy Media Creator 7
Roxio Creator 7 & Vista compatability
Any way to get Roxio Creator 7 to run on Vista? My old computer with XP crashed.  I have Creator 7 projects that I need to open on my new computer with Vista. I don't want to buy the upgrade because I've already ordered another video editing software.
  • mamalokeyb Jan 17, 2009
    There's nothing there Travis1995 - try again.
    Problem Solver:
  • 18 Answers
Download it again from
Posted on Jan 17, 2009
Kim komando website
The only thing that you can try is installing it in compatibility mode.
Feb 22, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Running Windows 7 and can't use my Photosuite 7 Platinum
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
May 03, 2011 | Roxio PhotoSuite 7 Platinum for PC
Creator 2011 says it is not combatible with Windows System 7 Home Premium and will not install.
Based on the Microsoft Website
Roxio Creator Pro 2011 is compatible with windows 7 so all you need to do is call Roxio and check if there is a discount for the Pro version since you already have the Creator 2011 and upgrade to Roxio Creator Pro 2011.
You can call this number: 877-793-7471 (North America only)
Mar 25, 2011 | Roxio Creator 2011
Roxio creator has stopped working windows 7
  1. Please be sure that you have met the system requirements of Creator.
  2. Defragment your hard drive. This will allow larger files that you have created to be more easily read by the program and allow more efficient writing of data for video and audio capture to your hard drive. To do this:
    • Go to Start -> All Programs -> Accessories -> System Tools -> Disk Defragmenter.
    • In the Disk Defragmenter window, select the drive (a.k.a. volume) you wish to defragment.
    • Note the Free Space column. If you have less than 10% free space available you may run into issues defragmenting. Additionally, the drive is too full to capture any new media to it. Doing so may result in the hard drive crashing and data loss. Unless more free space can be safely made, it is recommended that you purchase an additional hard drive just for your multi-media projects.
    • Click the Defragment button.
      NOTE: If frequently using your computer for recording and editing audio and video, defragmenting your hard drive on regular basis (about once a month) is recommended.
  3. Contact your video card manufacturer for the latest video card drivers. If you purchased your computer as a complete system (like Dell or HP), then go to the manufacturer's website for the latest drivers.
    If you purchased your video card separately, then you will need to find out your make and model and go to the video card manufacturer's website to download.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows 7 and Vista: Go to Start -> Control Panel -> System and Maintenance -> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Double-click Display Adapters. You're video card make and model is displayed.
    • To find out the driver details (such as version), right click on the make and model under Display adapter, and select Properties.
  4. If running Easy Media Creator for the first time, or it's been a while since you used it, RoxWatch will require a few minutes to index your hard drive for new audio, video, or photo files. This allows Media Manager to create a convenient list of all the files you can create projects with in a single window. Once the indexing is completed, Easy Media Creator will launch faster only looking for newer files. However, if you wish to disable this function, do the following:
    • Windows XP: Go to Start -> Run -> and then type "msconfig" and click OK.
      Windows 7 and Vista: Click on Start -> type "msconfig" in the Search field and press Enter on your keyboard.)
    • In the System Configuration Utility window, select the Startup tab.
    • Locate RoxWatchTray10 (or whichever version you are using) under the Startup Item column and uncheck it.
    • Click Apply and then OK.
    • Reboot your machine.
    • On reboot, you will receive a dialog from the System Configuration Utility. Check the box at the bottom of the window requesting not to see the dialog again and click OK.
    • Launch Creator.
Jan 22, 2011 | Roxio Creator 2011
Hi Name is Joe.
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
May 04, 2010 | Roxio Creator 2010 Full Version for PC...
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Cannot load easy creator 10 onto vista
i Think you do not have vista compatible softwares i.e.
Roxio Easy Media Creator 10 Suite . So please buy vista compatible software or path with vista patcher . You can easily download vista patch from . Patch and run the software in vista. Best of Luck.
Nov 06, 2009 | Roxio Easy Media Creator 10 Suite
Compatable software
Normally what you actually get along with the hardware is an oem licensed software. So if what you have is for xp then i regret to inform you that you will be needing a different software that you may need to purchase. Now, if you are open for a different software aside from roxio, what you could do is go to and search for cdburner xp pro which is compatible with vista.
May 28, 2009 | Computers & Internet
Will not load on windows vista not compatable
Previous versions of Roxio or Sonic branded software that are not listed below as Vista compatible may run into compatibility issues. The following Roxio applications that work with Windows Vista are:
Easy Media Creator 9 and above
WinOnCD 9 and above
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 and above
MyDVD 9 and above
You will have to upgrade the software to an vista compatible version:
Mar 01, 2009 | Roxio Easy Media Creator 7
Problem: Roxio easy creator 10 installed on Vista ...I have downloaded all the software updates...Videoware will not run....need help!
have you tried changing the compatibility of roxio. All you do is left click the main folder in which all the Roxio 10 suite is install go to compatibility tab and check box next to run this program in compatibility mode make sure that in the box under this it says window xp sp2 then hit apply. If this doesn't work let me know if you are using the 64 or the 32 windows vista and i can help more.
Oct 26, 2008 | Computers & Internet
Roxio Easy Media Creator 7 Logo
350 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
