Question about Canon PowerShot A310 Digital Camera
My power shot a310 does not have a picture on it when you open up the slide in the front but does have pictures when it is closed
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 17, 2009
Taking a picture
To turn the camera on, either press the power button (the big round button on top of the camera) or slide the lens cover on the front in the direction of the arrow.
To take a picture, compose your shot on the screen and then press the shutter release button (the long button on the top).
You may download the manual and more from here.
Jul 27, 2012 | Sony Cameras
Focus error (can't take pictures) A310 Fujifilm camera Camera shows "Focus Error" and does not take pictures
A couple of quick things come to mind first is you may be way to close to your subject for the camera to focus OR you are trying to take a pictures of a shiny subject, painted wall a mirror or some other subject that lacks contrast
Dec 22, 2010 | Fuji FinePix A310 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
LCD picture veiw is runny like a runny film
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 14, 2009 | Canon PowerShot A75 Digital Camera
I turn on my Canon Power shot A75. to take a
I have a power shot S2 IS digital camera. I have
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
For your particular model camera, pay attention to the UPDATE intro to the article.
Oct 12, 2009 | Canon PowerShot S2 IS Digital Camera
I have a power shot A310 the screen is black when taking a pic.
If you dont see live view to take picture in Canon A310 then its problem of bad ccd imager and this part need to be replaced.
Canon will repair A310 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Dec 20, 2008 | Canon PowerShot A75 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Canon a 310 takes so long to take a second picture, very slow
I have an A310, and really like the quality of the pictures and videos it takes. But what you describe is not unusual for this particular model camera. Lag between shots in bright sunlight is usually minimal, but may be very pronounced in darker conditions. It's caused by inefficient and slow charging of the camera's flash capacitor.
There's nothing you can do to modify the design of the camera to change this. But you can try to minimize this some by using batteries with higher power rating. Alkaline batteries will not work very well in this camera, even if brand new. Would instead recommend that you consider rechargeable NiMH batteries. They run about $7 these days for a package of four. But they'll save you big bucks in the long run. Look on the package for power rating of 2,500mah or better.
Mar 07, 2008 | Canon PowerShot A310 Digital Camera
Canon PowerShot A310 Digital Camera Logo
197 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
