Question about Yamaha DVR-S200 DVD Player
DVD Player Cannot get the tray to open. I've tried everything short of a crowbar to open it.
  • 23 Answers
Heh... I wouldn't recommend the crowbar. Their is a belt inside the drive underneath the actual reader, it's broken, happens alot. As to actually fixing that issue, you would have to open up the case and take it apart, can be difficult on some drives. I don't know where you could get a replacement belt either. I had to turn my samsung into a manual dvd player (I have to pop off the top, pick up the drive and slide over a pin to open it.) I wouldn't actually recomend that, I just didn't feel like paying to have it fixed. I couldn't find a belt anywhere. which left me with the option of going to a repair center. Probably your only option as well... Unless of course you do like the idea of a frankenstein dvd player. Good Luck
Posted on Jun 20, 2007
SOURCE:
Bad DVD player ( Karaoke )
Th fault is on your disk tray mostly. Just try to switch off your player once and then restart it again. If that doesn't work then try to open the screws in the DVD player only the disc portion and try to check whether there is a damage on the disk tray.
Nov 23, 2017 | Audio Players & Recorders
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
TOP MENU
CLEAR
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I get...you can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
Apr 27, 2011 | Sony DVP-SR500H DVD Player
Tray won't open.
hello,
the reason the tray wont open is because there is a problem on the mechanism that controls the opening and closing of the tray.
most likely the rubber that assists in opening and closing the disc tray.
to fix this, unscrew the player, turn it on and press the open button, it'll respond and stop.
you'll see a kind of mechanism that carries the tray, its engine is by the side of the tray.
when the tray stops responding after you've pressed the open button, try to carefully sit the engine properly and press the open button again and it will respond.
if you cannot do that on your own,try to take it to a service center for further repairs.
take care
May 30, 2010 | JVC DR-MV100B DVD Recorder/VCR
DVD stuck in tray of Panasonic RA60.
many dvd players have a small hole near the tray. if yours has this little hole just straighten out a small paper clip to form a straight piece of wire and insert the wire in the hole. That will open it up for you.
Aug 05, 2009 | Panasonic DVD-RA60 DVD Player
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
Yamaha DVR-S200 DVD Player Logo
116 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
