Question about HP Compaq ProLiant 800 Server
I have a compaq proliant 2500 series do i need a scsi adapter card for this or is it onboard
    Problem Solver:
  • 17 Answers
Open it up and see. there should be markings showing scsi card etc., if none, then it is not onboard . get one scsi card.
Posted on Jan 18, 2009
Smart array 5300 PCI-X 64Bit/66MHz in ML350 G5 server.
it will be a controller card problem / SA5300 is 100% compitable
Jan 17, 2013 | HP Compaq ProLiant ML350 G5 Server
Hello I have a query guys on hp ML350 server is that at the end of the inauguration of Windows blue screen appears You change the RAM first and then reduce Alhardat from three to two, but without the...
The system is not designed to use IDE hard drives which why you are getting a blue screen. It is designed to use SCSI hard drives and IDE CD/DVD drives. It might be possible to go into the server's BIOS setup and change the boot device from the onboard SCSI controller to the IDE controller. It is very likely that you will have to disconnect all SCSI devices to boot to IDE, if it is possible.
I hope this helps.
Nov 27, 2012 | HP Compaq ProLiant ML350 G3 Server
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
Prolinat ML350 G2 WONT BOOT UP
You have apparently attempted to attach a tape drive or other similar device to a SCSI RAID controller. You will need to get a separate SE SCSI HBA instead. These are pretty cheap, usually just over $100 list from HP.
If you haven't attached anything new, then you should check your cables first and if that doesn't help I would suspect a bad RAID controller.
Jun 10, 2009 | HP Compaq ProLiant ML350 G5 Server
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
OS Loaded on SCSI HDD Cashed
If the Bios did not detect the third drive, try switching it to a known working slot and see if you have a bad drive, or something wrong with the cage or cabling. The 3000 were shipped with either a 68 pin drive cage or a 80 pin drive cage. The 68 pin drives and the 80 pin drives are not interchangeable. To make matter worse, the drive cage would be configured as simplex or duplex. For duplex mode, you will need to connect two SCSI cables to the cage.
Dec 30, 2008 | Compaq ProLiant 3000 Server
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Scassy Card for Compaq Proliant ML 330 is defective
You cannot find the details of OEM of this card unless it is written on the card itself.
The card is HP/COMPAQ - SMART ARRAY 532 DUAL CHANNEL ULTRA160 SCSI RAID CONTROLLER CARD WITH 32MB CACHE.
If you want to use a different make card. You can safely go with a adaptec make card.
Cheers - Parveen
Feb 05, 2008 | Computers & Internet
I have allredy missing scassy card for Compaq Proliant ML330
what can i setup my server
Feb 05, 2008 | HP Compaq ProLiant ML330e Server
HP Compaq ProLiant 800 Server Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
