Question about Canon PC-1080F Copier
Will not scan
My copier/fax will not scan items. It didn't give any type of warning, no scanning problems in the past. The wheels on the 'output' side of the try will turn, but the actualy 'arm' will not move to scan the paper. So, I cannot copy or fax at this time. I tried turing the machine on and off, opening all 'doors' (like if I had a paper jam), I checked the paper supply. Nothing works. I can still receive faxes fine, but cannot send or copy
    New Friend:
I am having the same problem now, it was working fine and all of the sudden the scanner will not move, it acts like its gonna go and then it gives me an error beep. is there an easy fix???
Posted on Jul 16, 2016
  • 31 Answers
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Posted on Jul 03, 2007
SOURCE:
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
How do I scan photos
Although different scanner has different option still I am giving you the general method of scanning.
Put the photo on the scanner (photo face down touching the glass of the scanner) - look the cover is perfectly placed and no light is entering inside of the scanner. Now run the scanner software - select scan item as "Photo" (other options are text or documents etc), select the option "Color" (other option is Black and white or gray ). Select the resolution more than 200 dpi (more dpi will give better output), give path where the file will be saved after scanning or keep it default, choose the file type JPEG is better (other options may be BMP, TIF etc). First you get preview - look the expected scan output - if required you adjust or lace the photo on the scanner better way - then again get preview - if you are satisfied you may select the portion out of the whole preview page for scanning - now click scan. It will give JPEG file in the specified location.
Jun 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
We are getting streaks on scan and faxes but not on items we just use for regular copying. Where do you think the problem lies?
Clean all the glass surface you see. Newer copiers use a small glass strip that the original scans across. All it takes is alittle white out or ink spot on the glass and you get the streaks.
May 16, 2010 | Office Equipment & Supplies
What does NG mean for Status after sending a scanned item or faxed item?
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
Thanks.
Jun 25, 2009 | Toshiba e-Studio237 Grayscale Copier
How do I scan to my desktop using a dell 966 printer?
usually scanned items will be saved in the My Documents folder under a sub-folder named "Scanned items" or either in my pictures in a sub-folder, if you open the scan utility and look for the output folder, it will tell you where they are going. If this helps solve your problem please give a fixya rating, Thanks
Jun 15, 2009 | Dell 966 All-In-One InkJet Printer
How do I set my copier up to scan? I can copy and fax already but I would like to learn how to scan with it.
You didn't include the model number, which makes it very difficult to give any type of instruction, and if you want to scan I would suggest to start by installing the scanning software, and it may be somewhat explanatory after that
Mar 02, 2009 | Brother Office Equipment & Supplies
Photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Jan 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Mulitpass mp390
1) Push Fax button
2) Use number buttons to put in telephone number of where you want fax to go to.
3) Lay item to be scanned (faxed) face down on glass and press Start button (Black or Color)
4) Repeat step 3 for each item to be faxed.
5) When ready to send fax (done scanning) press Set button
Nov 26, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Trying to scan multiple items and email as one file
Press function- fax parameters-key opp mode- put password in- touch fax parameters- go to 183- select multi - ok.
now you can scan what you want
Jun 26, 2008 | Panasonic DP-C213 Color Copier
KM BH350 -- Scans a copy when I fax
Open a webBrowser and type the IP of the Machine.
Goto Onetouch and recreate the ones that are giving you problems
Mar 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
125 people viewed this question
Clive
Clive
old marine
old marine
Ekse
