Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
TV turns on for about 5 minutes then shuts off.
The tv works and then shuts off after about 5 minute then shuts off. Then the green light flashes. After we turn it off it will turn on for about the same amount of time then it turns off again.
  • nate0777 Jan 16, 2009
    Just a little more information. The sound shuts off a couple of seconds after the picture goes out and the light flashes green.
  • utot_99 Jan 22, 2009
    I have the same problem. I saw on one of the sites that it might be the thermal fuse. I ordered and replaced the thermal fuse bu the problem still remained. It will actually turn on for about a minute, shuts back off, then on again for a minute, then shuts back off again... and the cycle continues.
    good luck
The projection lamp is out and needs to be replaced.
Posted on Jan 25, 2009
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Tv turns on then after about 3-5 minutes shuts off and the green standby light flashes then afterabout 3-5 minutes tv turns back on
Most likely you need a new Lamp. This is a common symptom. I believe it is a XL2200 Lamp.
You could order it from Sony at 1800-222-SONY.
I hope this helps,
Oct 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green Flashes - Shuts off
Sounds like the green picture tube is defective. To confirm you can take the front grille and door off and tap the green tube lightly with something plastic, and not to touch any of the adjustment controls to confirm.
Apr 12, 2008 | Sony KP-57WS500 57" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
390 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
