Question about Sony VPL-PX15 LCD Projector Multimedia Projector
Bub dose not come on.
I just replace bub in my sony porjector vpl s900 bub did not come on .lamp/cover light came on &porjector when off .how do i reset bub timer.Are what do i do.I push the reset button.
  • 3 more comments
  • nathanielcal Jan 16, 2009
    original bulb was burned out.New bulb matching original.
  • nathanielcal Jan 17, 2009
    bulb comes on yellow lamp/cover light comes on projector shuts down.
    and it's a vpl-s900 sony projector
    yellow lamp/cover light on.projector. keep cutting off, just replace bulb.how do i reset bulb timer.sony vpl s-900
    still shutting off
  • Sony Master
  • 19,396 Answers
Try this:
"#12
"Connect the power cord and set the projector to standby mode. Confirm that the ON/STANDBY indicator is lit in red."
#13
Then quickly do the "Reset, Left, Right, Enter" thingy once you plug into the Ruby. I believe you have up to 5 seconds total to do it. It is not the less than 5 seconds each for "Reset, Left, Right, Enter"
From the manual.
Posted on Jan 23, 2009
  • 470 Answers
Theres a short circuit on it, because bulb is working improperly,, repair it with the technician , and find the short circuit,, that's the main reason why the bulb does not come on,, and suddenly it will burn,, be careful on it, dont make it worst go it with the technician as early as possible
Posted on Jan 17, 2009
    Genius:
  • 2,920 Answers
Have you cleaned the filter for the cooling fan? the bulb may not come on if its not able to breathe. clean the filter and then try it again
  • Ronnie Houston Jan 17, 2009
    is the cooling fan on the machine working? have you noticed if it comes on or not?
    Scholar:
  • 91 Answers
With the projector in standby, press the following buttons on the remote control:
RESET, LEFT (arrow), Right (arrow), ENTER.on the projectors control panel( hold for few seconds)
also Try unplugging and plug back in,
Do you have the right bulb for the unit? Did you check the inputs from the cable/dish box?
regards.
Posted on Jan 16, 2009
  • Sony Master
  • 13,433 Answers
Was the original bulb confirmed burned out? faulty?
Is the new bulb original or matching model, 3rd party models may not function properly.
  • Ekse Jan 16, 2009
    The lamp that works with this model is
    Sony LMP-600 http://www.aboutprojectors.com/Sony-LMP-...
  • Ekse Jan 17, 2009
    Go to the install settings menu and press reset on the lamptimer.
    Sony insists in this service manual that you can't reset the timer.
    There must be a away, but you should get picture out of the projector, it shouldn't reject the lamp when a certain amount of hours is used.
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
My Sony VPL CS1 projector was working on Monday and is not working on Wednesday. Smells hot but fan is running. Light was on but now it is not on and the Lamp/Cover light is on.
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
Dec 22, 2010 | Sony VPL CS1 Multimedia Projector
Lamp/cover light flashes
Did you replaced lamp in projector? if yes, please make sure lamp cover is fixed properly on its position. There is safety switch under lamp cover that needs to be pressed to turn off lamp cover light flash.
Thanks.
Oct 21, 2009 | Sony VPL PX31 Multimedia Projector
Need to change bulb in sony vpl-x1000 any advise
Yes, buy Original Sony Lamp and avoid aftermarket / cheap lamp.
May 05, 2009 | Sony LMP600 Projector Lamp for VPL-S600U,...
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
44 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
