Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
How to reconfigure router
Im trying to access the router but unfortunately when i am ask for a username/password of the tplink tl-402m router i cannot access. how could i open port for port-forwarding if i am unable to reconfigure the router?
i hope anyone could help me with this.
  • eecom May 11, 2010
    Hi...is this because the default password has been changed?
    The defaults for the model TP-Link TL-R402M are username: admin and password: admin
    If these don't work, and you don't know the password, you may need to reset to restore the defaults. However this is a last resort, and not recommended unless you are happy to set up the router again from scratch.
    Hope this helps to start with.
I reset it , but admin / admin still cant let me access my router . what should i do ?
Posted on Nov 12, 2009
  • help_me_john Nov 12, 2009
    i reset my router but admin/admin still not let me access to it .
    what should i do ?
    anyone have any idea pls
Why is my tp-402m ddnt work in my 2 pc?i ask if the problem is the range of 2 computer?? pls help me
Posted on Sep 24, 2009
  • 3 Answers
You may need to reset to restore the defaults.
the the default username: admin and password: admin
Posted on Feb 07, 2009
I have a netgear router and im not connected
Log in to your NETGEAR router by browsing to http://www.routerlogin.net/ or http://www.routerlogin.com./ Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply. If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Apr 09, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Slow internet connection with TP Link router.
im also facing that type of problem on tplink TL_WR340GD
May 27, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
I installed my DIR-615 router about 2 years ago and set it up with wired, not wireless, connections. I have forgotten my admin password and can't get into the router firmware to reconfigure for...
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Jul 07, 2011 | D-Link DIR-615 Wireless Router
How i can change my wirless net password
If you have forgotten your Linksys router password, the easiestthing to do is to reset your router to the factory default settings. To restore therouter configuration to factory defaults, hold the reset button on the unit for30 seconds.
Once your router is hard reset, you will need tologin and reconfigure it again.
To reconfigure your Linksys,connect a PC to one of it's Ethernet ports, load a web browser, and go to theURL http://192.168.1.1/. This will take youto a popup box which asks you to enter a username and password to login to yourrouter.
Linksys Default Password
On older Linksys routers, the default username is blank and thedefault password is "admin." On newer Linksys routers, both thedefault username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigurethe Linksys router.
You want to go to the management tab and change the administrator password tosomething else to keep others from accessing your router.
Apr 05, 2011 | Linksys WAG200G Router
I could not loged in to the web based configuratin page of 5210
Turn off the router.
Press and hold small reset button (usually with a pin or pen) for 1 minute.
While still holding the reset button, turn the router back on and keep holding reset button for 30 seconds.
This will completely reset your router. The username/password will be set to default. (Usually Admin/Admin)
Feb 28, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
How can i find my username for my my wireless router
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 28, 2010 | NetGear WNR2000 Wireless Router
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
Jan 07, 2010 | Computers & Internet
Clarification on the router configuration
The defaults are:
username: admin
password: admin
To reset, hold the reset button for 10 seconds without powering off.
Here's the website, just for future reference:
http://www.tp-link.com/support/download.asp?a=1&m=TL-R402M
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
529 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
