Question about Hunter Fan Company 5/1/1 Programmable Thermostat
The furnace won't stop at the programmed temperature set ponts
The furnace keeps on running when it should be shutting off. You have a 70 degree set point to shut it down and it's 71 degrees in the room, and the furnace keeps on running - why? Shouldn't it shut off as soon as it reaches 70 degrees?
  • 59 Answers
This is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Posted on Jan 21, 2009
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80. Any...
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Feb 09, 2015 | Heating & Cooling
I have a rheem furnace and a programable thermostat. I have the thermostat set to stay at 70 degrees. The furnace sometimes acts like it is going to come on but then shuts off. The temperature drop 2 to 4...
There are a few things it could be like the ignitor or the flame sensor is where I would start if the burners ignite then the ignitor is okay if they lite and then turn back off then the problem could be the flame sensor. The flame sensor you can take the flame sensor out and clean it with a piece of sand paper or emery cloth and it should sustain flame.
Feb 22, 2010 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
206 people viewed this question
Top Hunter Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
Paul Bade
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
