Question about Ricoh Aficio 450 Copier
Fixed one problem now another on Aficio 250
I got the SC900 code problem fixed...and corrected the power supply issue that caused fuse #5 to blow and set the SC900 code. NOw I cannot get the paper to pull from the tray and through the photoc. or fuser. Misfeed on A and B happen each time it operates. Is there a way to set timing on the machine? or is there somthing else that I sould do?
  • easttxtech May 11, 2010
    Tons of things can happen to cause jams. Sounds like you replaced a Power Supply Board or maybe the fuses? Touch any other wire harnesses that have to do with the paper transport sensors? Check to see if trays are set to correct size, fences at right position?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this happening to all the paper trays?
  • 227 Answers
Sounds like you may have missed a connection on the powersup unit that controls the paper feed board. No paper from trays= late jam detection @ A and or B!!!!
Posted on Mar 28, 2009
Ricoh Aficio 250 sc900 help
need replace the PCU unit as drum is damage and leaking the charge
Apr 20, 2014 | Ricoh Office Equipment & Supplies
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
I have a code error c4101 in minolta 350 bizhub
Does the machine come to ready state? and if it does, does the code blow as soon as an original in placed in the df or the start button is pressed?
Make sure you have 2 ribbon cables and one connector running through back of machine from PH unit. Also make sure you have the correct ph unit installed.
Here this is straight from Konica ...
C4101 code at power up.
Description:
Solution:
PROBABLE CAUSES:
1. Failed PWB-A (Mechanical CB).
Replace the PWB-A board (p/n 4040 0101 03).
2. No 24V DC at PJ17A, pin 5.
Replace the 3.15A fuse located on the power supply.
3. Polygon motor in the Print Head Assembly fails to turn.
Begin by checking the connections to the Print Head Assembly. Unplug and reseat all connections. If issue continues, replace the Print Head Assembly (p/n 4040-0751-00).
C-4101 (C4101) at power up.
Description:
C-4101 at power up.
Solution:
CAUSE: Failed BCRS board.
SOLUTION: Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
G.L.
Apr 24, 2011 | Computers & Internet
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
Lanier 5235 sc900-01
Hello sir; You may try to reset the machine follow the steps; Press "clear mode" "107" and hold down "clear/stop" key for 3 seconds, turn power off and back on .
Sep 19, 2009 | Ricoh Aficio 1035 Copier
Error code sc:553 showing ,what does this mean? machine won't work at all
Fusing overheat. Could be defective thermistor, or Power supply. Problem can only be reset in service mode after cause is fixed.
Mar 24, 2009 | Ricoh Aficio 2016 All-In-One Laser Printer
Ricoh Afficio 250 SC900 Code Reply
The problem is getting parts for 220s and 250s is tough. I'm running out of sources myself. Do you have any way of checking the power supply?
Jan 04, 2009 | Ricoh Aficio 450 Copier
Ricoh Afficio 250 code SC900
If changing the total counter the fault does not disappear, try pressing . (point) and # for more than 10 seconds. this reset and reload the software.
Jan 03, 2009 | Ricoh Aficio 450 Copier
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Oct 27, 2008 | Ricoh Aficio 250 Copier
Ricoh Aficio 450 Copier Logo
112 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
