Question about Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Tasco scope issues with elevation adjustments
I have an older Tasco scope. It is a variable power with target turrets. The elevation turret does not raise or lower the elevation.
How do you fix this?
  • Anonymous Mar 30, 2014
    I can't seem to get the caps off of the windage and elevation adjustment knobs. Any suggestions?
Take the lens caps ff.Then run a new Leupold under it..
Posted on Oct 16, 2009
If this is one of the old 600 model series from Japan, and it has a BDC option (dual horizontal crosshairs), the threads may be stripped on the plastic cap or sleeve that engages the elevation screw (common problem). The cap may also be cracked. You may have to be on the lookout (ebay, gunbroker, etc.) for a replacement cap. In the meantime, you can just remove the plastic cap and use a screwdriver to turn the metal screw on the scope body under that cap to adjust elevation. If this does not solve the problem, there is a scope repair shop that specializes in repairing vintage scopes (Ross, Ohio). This work would be beyond the "scope" of an amateur. Hope this helps. erik7x57
Posted on Apr 29, 2009
How do you sight in a redfield scope
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Jul 26, 2014 | Redfield Optics
Bullet spares hyderabad
You may need to send the scope into Zeiss to have the turrets changed. The folks at RCS Optics Customer Service will help you out. Email them at customerservice@rcsoptics.com or contact them online at www.rcsoptics.com
Jul 04, 2013 | Zeiss Optics
Do i have to loosen set screws on turrets to zero scope or do i zero and leave the set screws where they are to shoot at different distances? thx. 6x24x42 varmint with mil dot reticle.
Sight in your scope, Loosen the set screws and zero the dials the re-set the set screws. This will make it easy for you to adjust for distance and wind from the zero setting when in the field shooting. Then you can go back to your zero.
Sep 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I have tasco #62TR rifle scope. I has stadia crosshairs and an adjustable top turret with various ranges for elk, deer, and antelope. However I cannot find any paperwork describing these features, and I...
Sight in rifle and put the on top turret with zero facing back.do not let knob"click".Aim at animal and adjust power(3-9etc)until body is bracketed by both crosshairs.Look in little window in eyepiece for type of animal.Click top turret to proper yardage(200,300etc).This allows for bullet drop.I've had one on a .270 for 30 yrs and never used this feature.
Dec 05, 2010 | Tasco 3-9x Variable Riflescope
Elevation turret stripped out. Entire turrent turns with no adjustment . Turret came off when reinstalling cover. Was not forcing cover tight and had just started to tighten.
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
Sep 05, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I can get the elevation adjustment cap off. Is there some secret to elevation adjustment?
if the scope is out the best way to set it up is to clamp the rifle in a jig or hold it hard done on a sand bag,,,firs off the first shot at the bull and see were the shot hit the card,,,now without moving the rifle turn the scope turrets till the cross is over the bullet hole from the last shot,,,now again aim at the bull and shoot again,,,the shot should hit the bull,,if not reajust the scope as before,,,
Aug 31, 2010 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Is there a way to lower my turret after i've found my zero? my zero is at the 4th vertical tic mark on the 0.
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
May 24, 2010 | Leupold Long Range/Tactical M1 Mark 4...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss CONQUEST 3-9X40 MATTE Z PLEX Logo
742 people viewed this question
Top Zeiss Optics Experts
Mark Campeau
Level 1 Expert
Tom Chichester
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
