Question about Microwave Ovens
GE Spacemaker microwave running, then hummed, then died
Checked circuit breaker, outlet, etc.
  • 1 more comment
  • hodg Jan 17, 2009
    THEN..........it did NOTHING. Won't turn on, won't do a gosh darn thing.
  • hodg Jan 17, 2009
    Thanks. I just replaced one in one of my rentals -- it would have cost more to fix it than to replace it! I appreciate your help and quick response.
  • BOB  BROWER
    BOB BROWER May 11, 2010
    THEN .......... WHAT do you want me to guess what it did ?
    President:
  • 267 Answers
The magntron has shorted out , then it blew the fuse inside unless you realy LOVE this microwave you should not put money into it . if its the best thing ever ! , parts should cost around 100.00 + labor . ge microwaves go through magntrons all the time , just poorly made .good luck
Posted on Jan 17, 2009
Boiling water in my GE Spacemaker Microwave it stopped working and looks as if it is at half power. When activated it makes a half power type noise and the light goes dim. Is this a fuse issue?
Probably not a house fuse. Typically good or bad!! Have you tried it in a totally different outlet?? Could be a bad connection of your circuit breaker to the bus bar in your circuit breaker panel. Try it on an outlet on a different breaker. Or have someone check the power at the outlet when it is running and see if the voltage is dropping.
Sep 13, 2017 | GE Microwave Ovens
I was just using the microwave and it died on me. No power to the unit that I can tell.
Check the circuit breaker. If it's pugged into GFCI type outlet or an outlet that's run from one, make sure the breaker didn't trip there.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker2. The toouch screen does not respond
could use a little more detail.
when u have no display screen the solutions are. possible causes * A fuse in your home may be blown or the circuit breaker tripped. A. Replace fuse or reset circuit breaker
* Power surge. A. Unplug the microwave oven, then plug it back in.
* Plug not fully inserted into wall outlet A. Make sure the 3-prong plug on the oven is fully inserted into wall outlet.
* Door not securely closed. A. Open the door and close securely.
Jan 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is tripping the circuit and shutting it off.
could be short in microwave or bad breaker.I would try microwave on an outlet connected to a differant breaker first
Oct 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dead micro
It could be a bad in-line circit breaker fuse. Unplug the microwave and take the outside cover off. Look for the in-line circuit breaker fuse. Use a plastic fuse puller (not your hands or a metal tool as there is still voltage stored in the microwave even when it is unplugged). Look at the fuse and see if it is blown. (The metal wire running length of tube will be broken. If you have one, test with an Ohmmeter.
Jun 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
